4.88 Ring gear - Centre pin problem
Cape Town, South Africa
Finally I received my 4.88 ring gears in the mail, totally excited I had them fitted into the thrid member, but now I have a problem!!!!
The centre pin that holds the 2 planetary gears cannot slide in as the ring gear is thicker than the oem gear... any ideas on how to solve this one?
OK, just found it under the search, sorry for the panic! Seems I have to grind some gears.... feel sick having to grind brand new gears like that!
krzyabncanuck
USFS HOTSHOT
GOLD Star
NC
FRom what I know and have had to do, anything 4.56 and taller you have to do some grinding. I did on mine anywas.
outside if possible
Correct. Take a die grinder and remove just enough to get the pin in. This doesn't affect the running of the gear set at all though, it is quite diconcerting grinding away at a new gear!
krzyabncanuck
USFS HOTSHOT
GOLD Star
NC
Its still scary the amout you have to take off of a 4.88 set. But mine is still running up and down the road.
