read my sig , 5.29s ftw.
They aren't "bad" on the highway. You doing 90 with 4.88's is going to be higher RPM than me doing 70 with 5.29's.
Not sure how useful that is. Not a comparison of any kind.
if there is a formula what is it?
Right now it is basically a daily driver that wheels from time to time. my trend has always been to go to bigger tires eventually. So far on this truck i went from 315s (34.5 inches tall) to 36s (35.5 inches tall). the 36s are 15.50 wide (actual width 14.5 inches) and really noticed a slow down when i upgraded from the 315s to 36s. Which is what got me thinking i need to regear. i plan on wheeling it more in the future. i rarely go above 70-75 mph.
Probably the only reason i would go as low as 5.29s is because there is not a significant transfer case low range available for the 80 that does not call for signifcant modification. So my reasoning is to go as low as possible to make up for the tcase. i have been told that the automatic makes up alot for the lack of low t case gearing but how much? is there a mathematical formula similar to the formula used to figure out what ring and pinion you need? i know thats an easy question to answer!
something like:
1st gear x tcase gearing x ring and pinion gearing x auto torque converter slippage multiplier = the holy grail 100 to 1 crawl ratio.
