4.3L(264ci) V6 FI2002 inFJ60
:)I was thinking of trying a Chev V6 in a stock FJ60 Using a Mark's bell-houseing adapter.Any ideas vs V-8 (HP,Torque,Economy etc)and would the wireing be extemely complicated. Thanks Bill
esh
Oregon
Results are disappointing in a 4000lb FJ40... therefore in a 5000ish lb FJ60 they would be worse.
Mike S
The Vortec 4.3 V6 puts out much more power than the 2F. GM describes this engine as, "...Strong torque, high specific power and smooth operation make the Vortec 4300 V6 a perfect fit for sport utility and commercial applications requiring performance, reliability and durability."
Displacement: 4300cc
Configurations: Overhead Valves (2 valves per cylinder).
Horsepower: 190-195 hp @ 4400-4600 rpm
Torque: 250-260 lb-ft @ 2800 rpm
Applications: GMC Safari, Savanna, Chevrolet: Silverado, Express, Chevrolet Astro/Express
What is disappointing about the performance of this engine in a 40 or a 60?
M
esh
Oregon
Mike- much less low-end torque. makes the purpose of what a cruiser was built for (going slow), something completely different. look at the curves between Toyota's engines and that V6 and tell me you'd rather the 4.3 for poking around the hills. Maybe if one were rallying more it would be suitable?
blake- if you're seriously considering a swap, pick something inline vs opposing cylinders
Mike S
Well, I guess everything is a compromise. The 4.3 Vortec is pretty torquey down to about 1800 RPM. Many people swap engines because they want better highway performance. I like the 2F for backcuntry work, but it sucks pulling a trailer over Lolo Pass.
There is a potentially great GM engine for a cruiser - the Vortec I6 with 275 HP that is used in the Trailblazer. Unfortunately the configuration on it is such that you cannot readily change transmissions and are thus limited to a Chevy drive train. Not the best of all possible worlds.
Go Toyota turbodiesel is my idea.
M
M
Not saying it's a bad motor cus I dunno but when I drove the trailblazer it seemed flat until the mid range.
...how about a 4.3 out of the typhoon/cyclone :D
dieseldog
She idles just fine . . .
GOLD Star
Houston & BFE
Texican is doing (has done) a fantastic tech write-up on a 4.3 swap into an FJ-40. I believe it is in the 40/45 tech section. Lots of pics, and drive info. He even installed Vintage Air unit. Then see what you think. (I can't believe I'm saying this, as I'm a hard-bitten diesel guy . . . .)
Edit: here is the link: https://forum.ih8mud.com/showthread.php?t=43710
