Or.....just go to 37's. You have the room and you know you want to.
In Post #38, pic #7, What is the hose coming down next to the traction bar? Yours is a 60 so it’s not a LSPV….
In pic #9, the spring bushings on the passenger side don’t look new. Is that just some weird green moly grease coming?
Can you explain why you went with the modified upper rear shock crossmember? Why not use the existing mounts or move the mounts out but on the same bar? Is the performance gain worth the extra effort in fabbing a trussed bar to run off the existing shock crossmember?
I like that rear shock crossmember. Do you know what your caster turned out to be assuming CnT was done?
