I am currently running 4:56, h55f tranny, ranger torque splitter, on 35's with a 383 stroker V8. LOVE IT on and off the road!
As far as your drive shafts...... The rear will be fine however, the front you will of course need a cut and turn done and then since your 60 is a 1983 you already have the double Cardon shaft for the front. The front will need about 4 1/2 inches added to it.
One thing I recommend is leaving the stock springs. If they are a bit flat....GREAT. leave them that way. Dont have them re-arched or add any. I found that the rig rides better with the flatter spring verses the heavy arch.
Have fun with it, good project. Also LEHIGUY hit right with the welder recomendation of a lincoln, miller, or hobart as a fine choice as the amperage is way higher then the Bunk companies putting out 110 welders.
