4:11?
Discussion in '40- & 55-Series Tech' started by Mrpoopypants, Mar 8, 2004.
  1. Mrpoopypants
    Mrpoopypants Guest
    What is the stock gearing in a 78 FJ-40?
    4:11 is what comes to mind.
    If they differ, how can i tell what mine are?
    Thnx
  2. Cruisergreg
    Cruisergreg
    1,846
    2
    Jul 20, 2003
    That year might 3.70.
  3. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,296
    Media:
    17
    Albums:
    1
    591
    Oct 1, 2003
    MN
    Pull the rear cover, and count the teeth...that would remove all doubt.
    If this truck has not been messed with by a previous owner..I know, ha ha ha, but this *should* have the much saught after and coveted fine-spline 4.11 gear set, as in the USA, depending on the month of production, the 3.73 ratio was not in the 40 series until the 79 modle year, which could have started in 08/78...
    There is a tag on the passenger side bulkhead that has an axle/gear ratio code..
    Should have a 'K08' which would be 4.11, or a 'K05' which would be a 3.70...
    But I still think that removing the cover is the best way to verify a gear ratio...
    Good luck!
    -Steve
  4. s79bj40
    s79bj40
    359
    Feb 10, 2003
    Brisbane
    why did america get covers on the diffs and we didn't? I have never even seen a cruiser with a removable cover, they are all welded closed and if you want to count the teeth you need to remove the carrier. It would have been nice to have a look see inside.
    sam
  5. Toyoland66
    Toyoland66
    440
    68
    Feb 3, 2004
    Colorado
    You are acting like you all got screwed by not having removable diff covers......
    The reason your are welded up is because they are full floaters, US landcruisers got semi floaters in the rear and the cover needs to be removable to get the C clips.
    I'll trade if you want.......
  6. s79bj40
    s79bj40
    359
    Feb 10, 2003
    Brisbane
    must just be cheaper welding the back on, just be thankfull you dont have a landrover, mine has semi-floaters and there is no access cover.
  7. Poser
    20,296
    Media:
    17
    Albums:
    1
    591
    Oct 1, 2003
    MN
    9" Fords, and there are other axles out there that are the same way...
    Really not that big of a deal...
    Good luck!
    -Steve
  8. Mrpoopypants
    Mrpoopypants Guest
    OK, I checked the plate on the fire wall:
    Trans/Axle = H42 K082 :D
    Plate on the door frame:
    Nov 1978 :-\
    And I do have a removable cover on the rear.
    A-B+C=4:11? :beer:
  9. woody
    woody unhelpful spotter Staff Member Admin
    10,726
    Media:
    317
    Albums:
    8
    2,326
    Jan 15, 2002
    Toquerville UT
    I know of someone who ground off their front welded diff cover, drilled and tapped it for a rear bolted cover, and did it that way...neat idea.
    Mort, you need to count driveshaft rotations. Put the rear axle on jackstands, put the t-case in neutral, and rotate the driveshaft by hand. if it takes more than 4 revolutions to spin the tire one rotation, it's 4.11. Less means it's 3.73.
  10. incogrhino
    incogrhino
    641
    45
    Feb 29, 2004
    ravenna Mi sittin 10 deep.
    My 12/78 fj40 has the 4:11
  11. FJ40-GARAGE
    FJ40-GARAGE I`ll be back....
    794
    Media:
    32
    Albums:
    2
    296
    Dec 23, 2003
    Dorfweil / Germany
    My 4/1977
    has 3.70 and Drumbrakes on the Frontaxle..............
    Okay......... it was bought in Germany .......... :D made for the Autobahn.
    With the Original Tires that was easily good for a 100 m/pH .
  12. yooper
    yooper SILVER Star
    4,131
    Media:
    6
    Albums:
    1
    282
    Sep 17, 2002
    Da Yoop
    It's not 4:11, it's 4.11:1
    The : indicates a ratio, so 4:11 means "a ratio of 4 to 11", when in fact we mean "a ratio of 4.11 to 1"
    This is trivial nomenclature, but I'm a trivial kind of guy.
  13. cpip
    cpip
    64
    Mar 10, 2004
    Texas
    What are the higher gear ratios (lower numerically) that could be swapped into a '69? I am looking at a diesel swap and need to lower rpm's and raise road speed.
    Are new gears a possibility?
  14. bad_religion_au
    bad_religion_au
    2,213
    2
    Apr 24, 2003
    the 3.70:1's should bolt in should they not???
