3spd Tranny Swap Options
Harrisburg, NC
Hello... newbie with hopefully a quick question. I'm looking at swapping out a 3spd for a 4spd (or 5spd if possible) tranny.
Ease of installation and cost are VERY great concerns. I would probably put ease of installation above cost (within reason). This is not a daily driver, but will be making visits to Uwharie and driven around town. It currently runs 33's. What options do I have???
Thanks!
Sorry I dont have an answer to your question, but where are you located if you are going to UNF? I'm in Raeford, just outside of Fayetteville.
Good link and advice... The stock 4spd should work fine IMHO. Thanks!
I like the part list provided in the above link, but any good ideas where I can get everything? I could hunt the classifieds and ebay, but if there is another good source please let me know.
Also, any idea on how much I should plan to spend on these parts? If anyone has done this and could give me a high and low figure it will also help me when I'm buying parts so I know if I'm paying too much... Thanks Again!
I'm in Harrisburg, NC :D
FJ40 & FJ45 Parts Landcruiser Parts They all you need for the swap for 750. probably find parts cheeper by themselves
good luck I am doing the same thing. Will message u if I find a better option
Hi All:
O.K. - I have to why you want to swap out the existing three speed transmission? Is it broken or worn out? If so another three speed tranny is the "cheapest and easiest" option.
A four speed tranny will not allow the vehicle to go any faster at highway speeds than a three speed does. There are a few different four speed options out there - the GM SM420 and SM465 trannies that are super-tough and offer very low gearing for off-roading crawling; and the Toyota H41 And H42, which are both strong and smooth shifting with the only difference being that the H41 has a "granny gear" first that is great off-road while the H42 is more street friendly.
None of these four speeds will be a straight bolt-in replacement like another three speed would be. Various adaptor bits will be required.
On a budget, the H42 Toyota four speed is the best general use transmission. The GM SM420 is the budget low gearing winner.
Regards,
Alan
Thanks!
