3spd t-case to 4spd tranny
I've got a '79 fj40, I am planning to put a 3spd t-case on the 4spd tranny. But I need a pinion, I dont know where to get it. It has to have the inner part of the 4spd trannys axle and the outer part of the 3spd t-case. I know it exist, however I dont know where to get it.
Just use the 4sp transfer case. It isn't worth the trouble just for a 15% lower low range. You want 200% lower to make a difference.
Pinion?
Are you talking about the transfer case input gear that rides on the 16 spline output shaft of your four-speed transmission that has the correct teeth to mate up with the three-speed transfer case gear set?
These can be found from many a vendor out here...
However, I agree with Charlie;
The very minimal gearing you gain is not worth the screwing around to get it.
:meh:
Yes, that is the gear that I need, I'm from ecuador, and here it is difficult to find parts, I broke my 4spd t case (3rd time), and the only case I got is the 3spd, so I'm forced to use it. Where can I find it, and order online, so I can have my tlc running again...
