- Location
- United States
Need a 3spd front driveshaft (not the whole thing-just the long tube part).
This is why-
This is why-
CruisinGA said:I don't have the shaft with me to measure, I donated it to the Urban Land Cruiser shop "Frame of Shame" (old frame stacked with broken cruiser parts).
I can go measure a 3 spd front shaft tomorrow and then we'll know for sure if it is correct.
Thanks!
trainrech said:That's a really easy re-sleeve job. Just need 1.75 od x .083 wall thickness DOM tubing. It'll sleeve right over the top of the old tubing (once you cut the twisted sections out of it, of course). I bought my tubing at a truck repair shop.
Yotahilux said:IF the above does not work out, I have the frotn DS out of a 71. I believe that it is in one piece.
Living in the Past said:I don't think a SM420 with a adapter will be the same length as a three speed if that's what your running. "74 FJ40-- wheelin rig-SM420 " Is your's a early 74 with three speed? The SM420 with the earlier adapter was about the same length as the four speeds? If your going to have to change the length of your drive line might just want to retube your old one unless there's other problems. I saw this thread and thought there's noway a stock three speed could do that to a driveshaft but I could be wrong, it's happened before.
John
CruisinGA I'm buying a 3 spd front driveshaft for the rear of my truck. It just so happens that the front 3 spd shaft is the perfect length for a truck with an SM420, .75" adapter, and flipped rear springs.
I did this to a driveshaft with an SM420, in granny low, bouncing up and down on the rear axle alone. It was fun.
