- Location
- United States
Updated: 4/3/12
I have some parts from a 97 Toyota 4Runner Limited 4x4 for sale. Most will interchange with 1996-2002 4Runners. All I have is what is listed. Pickup on the larger items, or can ship on your dime. I am near Santa Rosa, CA (North Bay). I only have what is listed. Some of these parts also work on the Tacoma.
I do NOT have any engine/trans/transfer case, doors, dash, seats, console, fenders, hood, bumpers, etc. If it's not in the pictures, it's unfortunately not available.
Drivetrain/Suspension/Frame/Underhood:
Front Differential. ADD. 4.30 gears. Complete with breather and vacuum tubes. No leaks, works good. From a daily driver. Fits all 96-02 4Runners and 96-04 Tacomas. Stored out of weather and with ends covered. $200
https://picasaweb.google.com/lh/phot...eat=directlink
Control arms. Driver's upper and lower. $10/each
Ball joint - lower. Driver's side only. Good shape. Perfect for a trail spare. No idea how new/old it is. $10
Sway bar, front. No brackets or bushings left. $20
Coil springs/struts. Front. Stock 97, V6, 4x4, $20 pair
IMG_4980 | Flickr - Photo Sharing!
Coil springs. Rear. Stock 97, V6, 4x4, $20 pair
IMG_4978 | Flickr - Photo Sharing!
Heater valve (underhood), $10
IMG_4984 | Flickr - Photo Sharing!
Vacuum canister, $5
IMG_4982 | Flickr - Photo Sharing!
Hood release cable. Moves smooth. $5
Exhaust heat shields. V6. $5/each.
Bump stops. Rear end, frame side. $5 both.
Splash shield. Passenger's side inner fender behind A arms. Rubber. $1
Splash shield. Driver's side inner fender in front of A arms. Rubber. One hole ripped. $1
Interior:
Emergency brake handle, $5
Steering column with ignition switch with key, $30
IMG_4974 | Flickr - Photo Sharing!
Heater and a/c box from under the dash, $40 for everything. No fan.
IMG_4989 | Flickr - Photo Sharing!
Sliding glass sunroof assembly in nice shape with sliding cover and drain tubes. Oak in color. No motor. $50
https://lh3.googleusercontent.com/-R...0/IMG_5086.JPG
https://lh5.googleusercontent.com/-Y...0/IMG_5085.JPG
Passenger side rear seat area trim panel, $10.
Rear cargo floor trim piece, $10.
IMG_5008 | Flickr - Photo Sharing!
Rear cargo compartment side panels (nice shape), $20/each
IMG_5006 | Flickr - Photo Sharing!
IMG_5005 | Flickr - Photo Sharing!
Front A pillar trim. $10/each
IMG_4977 | Flickr - Photo Sharing!
Front A pillar grab handles (by windshield - NOT the roof mounted ones above the doors) "oh sh-- grips". Oak in color. I have three screw covers, and am looking for the 4th. No screws. $5/each
https://lh4.googleusercontent.com/-e...0/IMG_5081.JPG
Passenger's side front seatbelt B pillar trim. $10
IMG_4998 | Flickr - Photo Sharing!
Cargo cover holder trim. $5/both
IMG_4992 | Flickr - Photo Sharing!
Weather strip. Rear door body side, good shape. $15/side.
Steering column to rack driveshaft/u joint assembly. $20
IMG_5002 | Flickr - Photo Sharing!
Steering shaft floor collar. $5
Rear seat back hinges, $10 all
Gas pedal assembly with cable. For V6/Auto/4x4. $10
Dash brackets - radio area. $5 both.
Cargo area undercarpet rubber mat. $5
Jack area mat/insulation. $1
Firewall insulation/pad. Complete in great shape. $20
Rear seat back latch strikers. $5/both
Seat belt height slider mechanisms (front seats). $3/each.
Dash support beam. $10
Fuel tank wiring floor cover plate. $3
Exterior/Body:
Rear taillight harnesses. $5 each.
IMG_5032 | Flickr - Photo Sharing!
Door hinges, $5/door (driver's gone)
Rear hatch hinges, $5/both
Door latch strikers. $2 each.
Rear hatch latch striker plate. $5
Rear hatch rubber bumpers. $2 each.
Limited Rocker Panel Trim brackets. $6 for all 4.
Cowl panel. Good shape, but some some small dings. $15
Cowl to hood weatherstrip. Nice shape. $5
Windshield wiper arm. One. With nut cover. $5
Windshield wiper linkage. Under cowl. Passenger pivot broken. Works well. $5
Gas door release mechanism. Works good. $3
Gas lid release cable. Works smooth. $5
Gas door. White. Good shape. Nice paint. $15
Body plugs. Rubber or plastic. $0.50 each.
Fuel System:
Gas filler tube shield $5
IMG_4981 | Flickr - Photo Sharing!
Gas tank filler tube with fuel cap. Metal and rubber tubes. Rubber in good shape. Vent gas line cut where it meets the tank, but can easily be replaced with 8" or so of standard fuel line from auto parts store. $40
Gas tank strap. $5
Again, I am in Sebastopol (North Bay) near Santa Rosa, CA. The big items will need to be picked up or some other arrangement. I will ship the other stuff on your dime. Thanks! PM me your needs and I will get back to you. I want this stuff out of here! Make me an offer!
Vacuum canister, $5
Interior:
Exterior/Body:
Fuel System:
Gas tank strap. $5
