Hi
I've just started a rebuild of my H55F, which ran fine at 500k+ kms (it's not the original so true kms are unknown), more for preventative maintenance and infernal oil leaks than to remedy a specific issue.
I just measured the thrust clearances of the gears: 1st and counter 5th are like new, 2nd is on the upper limit, and 3rd is just above it: 0.35 mm when the limit is 0.30 mm.
I'm not overly worried but would like to sort it. I assume the sure way to fix it will be to replace 3rd gear along with the 3rd gear bushing (which also acts as a thrust washer for both 3rd and 2nd gears as far as I can tell), but is one more likely to wear than the other? The bushing is significantly less than new gear(s), is it likely that replacing just the bushing will bring 3rd gear back into spec?
Thanks for any help
EO
Thanks for any help
EO
