Asking advice from the experts (you guys):
There's another dude with a current thread that's installing PS on his 40 using a pump and mount from a 3FE engine.
He has inspired me to do the same conversion, but my "problem" is my F head does not have the 3 attach points as a 2F or 3F head. Mine only has the 2 for the engine hoist fitting, the lower attach hole in the mount would be sort of hanging there in space, un-supported.
So I COULD bolt up the 3FE mount using the 2 I have, but the lower mount point in the bracket would be un-supported. If I were to tack-weld a spacer on the bracket near the lower hole so that as I torque up the 2 top bolts, the spacer will JUST bear up against the head, I believe this will provide enough stability for the mount to work.
Opinions? I am hell-bent on mounting the pump on the right (passenger) side, so don't suggest going to a Sag pump. Will it be stable enough with just the 2 bolts?
