- Thread starter
- #21
Fuseable links replaced, in-tank fuel sock replaced, MAF back to stock and 1, 2, 3, and 4 teeth rich....still nothing! Starting to get aggravated here...anything new to try that doesn't cost $100+?
ok my 88 only has a hole for the sender anyway run a new wire/why if its the same design as the 62 which im sure it is the is a connecter in the drivers side rear quarter that JUST LOVES TO FAIL. folks will spend hundreds of dollars trying to fix the traouble then learn this is what it was ask me i know, anyway hell its free give it a shot. just run a new hot wire . its in your wiring i knowThis is on an FJ80, so there's already a hole there..makes life easier. The fuel pump is grounded right at the tank, all wires that I could see looked fine. Can the hot wire for the fuel pump be found under the hood, or am I looking at running new wire from the tank to the fuse block?
if the wire thery turns out to be wrong. then when it dies dont try to start it. just turn the key on and do a fuel pressure reading, even if its beside the roadSome more info: the engine has completely died on me three times now, until this week it would never need to be turned over, but twice in the past 2 days things have lit up like a x-mas tree so I had to throw her in neutral and spin her back to life, twice while driving, once while idling.
mine only had 2.what colors are theyNo connectors in the quarter panel for me, just a 4 wire connector right above the fuel pump..which one is the hot wire?
dam i forgot all about that pesky ground wireLook at the coil and ignightor. There is a ground to the ignitor but that ususally is an "all the time" sort of issue.
Does it/did it get worse after driving a while or now that the weather is heating up? I chased that for a long while and it was the ignightor heating up and cutting out. Change it out with a known good used one.
well you know then its a possibility now my experience with the cruiser igniters is they either work or they dont. but the ground is a issue on alot . not saying that they cannot slowly fail but they normally dontIt's buttoned up now, but i remember blue, black, and red....
i had a oem fuel pump on my old 40 do that cold water and she would fire right up , no i was thinking the 91 coil was the same as the 88/62 and its notYep, I have only seen 2 fail slowly but both did exactly what you describe. Try this.
Keep a midget in your back seat and arm him with a squirt bottle of cool water. When this happens have him/her jump out and spray down the ignightor. The quick drop in temp will get it working if that is the issue. It will get worse with time.
Its best to slow down or stop the truck before you send out the midget; unless ya got a fast one.
