3fe FJ80 Real time help overheating w/ trailer
I am moving from CO to CA have only made it 400 miles in 2 days due to overheating issues... My 91 FJ80 (3fe) pullling a 6x12 Uhaul trailer is hating me right now. I am doing most of my pulling in L or 2, but it still wants to get hot on me... Sometimes I can drop it from 2 to L and get the Revs up around 4200 and it will cool right down, other times it won't and I'm having to pull over and wait 30 min for everything to cool down. I have plenty of antifreeze, brand new fan clutch, and no leaks from the weep hole or radiator. Any help is appreciated, as I have 750 miles to go still. Trying to decide plans of action, I am currently outside of Provo where there is a dealer and plenty of services nearby. I have tools and will answer any questions I can. A couple of times I haven't made it more than 30-40 miles w/o having to stop before it gets into the red. Thanks for any help.
-LH420
A little history would be good. Like have you ever towed before and NOT had this happen? Who did the fan clutch and whose part is it - NAPA?
DougM
Never towed w/ it before this.... I have had it around 6mos and lived in Breckenridge CO (10k ft) with few issues. The fan clutch is a new OEM from CDAN, put in by myself. 140k miles, garage kept by PO. I have never really had any issues before, it was warming climbing steep grades over 10k and the Fan clultch was going out so I replaced it. I know I am pulling a pretty good load, but it certainly should go further w/o getting hot. I am thinking I will have the Rad flushed tomorrow am, and see if that helps. Otherwise I hvae no idea what the issue is. It is fairly flat for most of the rest of the trip, but I definitely still hvae a couple of major climbs left,and somoething is clearly wrong.
Any more ?'s to help out the diagnosis
-LH420
1991 3fe FJ80 w/ 6x12 Uhaul trailer
50/50, just checked all the belts, been watching fluid since before I left CO. I kind of figured if it did ok at 10k ft it would only get better at lower altitudes. I think it is just the weight and heat in UT combined w/ a possible radiator issue. I think I will still go get the rad fluched in the am, and see how it does between here and SLC before I head on to CA... at least there is another dealer in SLC if there is an issue. I have been told that I80 is pretty flat at least through UT, so hopefully I have already past the worst of it. Let me know if there is anything else to check, or have checked tomorrow. THanks for the helps guys, you are awesome!
-LH420
Since you're on the road, the coolant flush is about the best option. Keep in mind your tranny is putting a lot of heat into the cooling system and a stressed tranny will put a LOT of heat into it. If your tranny fluid is not proper, that would also heat things up. Wouldn't explain this, but worth checking the level and sniffing it for burnt smell. You might also pick up a spray bottle of Simple Green degreaser and soak the radiator fins with it front and back before spraying the degreaser out. Will maximize heat transfer with bare/clean fins that probably have quite an accumulation of normal road grime and dust.
Be sure the rear heater lines are flushed as well and someone here can chime in where the block's coolant drain is.
DougM
My experience with a 3fe in a 62 was that (after flushing the radiator and replacing the fan clutch) actually replacing the radiator made the biggest difference. That may not be an option right now. An external tranny cooler also helped but I believe the 80 already has one. Aside from flushing (while on the road). Keep it slow and choose a gear that keeps the rpms reasonable and locks up the torque converter to minimize any extra heat from the tranny. I might consider yanking my thermostat temporarily to increase flow.
Un bolt your hood and strap it to your roof and see how she does. Thats what I would do. OR
Loosen all four bolts and move the hood forward. It should move quite a bit enough to clear the rubber firewall gasket and still close normally, but create an exhaust for the heat thats building up under there. Then turn the heater to fresh and put it on HI and go!
You may want to drive in your underwear cause you'll be hot but you just might make it
This will not happen cause it only locks up in 4th gear, unless you have a Rodney special which give you lock up in 3rd also.
My guess is too much heat being added by the transmission. PO probably never changed the fluid. Running in 1st and second up and down the mountains is going to kill the tranny if it hasn't already.
My suggstion is rent a hertz box truck. Put the cruiser in it and tow the trailer. Getting stuck on the road is no fun, and you still have to cross the desert(maybe?). Good luck..
Breck to SoCal 900 miles IIRC. It's been a LONG time since I drove it.
Only suggestion I have is to run windowns down and heater on full blast.
The worst is over after CO. Utah has a few small grades and depending on if you are taking the 8 the climb out of El Centro is kind of steep but not Colorado bad. The 15 just has the grade out of Nevada and out of Baker. I bet he made it.
