3f sump gasket replacement and sealing no 5 bearing cap
Australia
Hi..I am in the process of replacing the sump gasket on my 3f motor but I'm not sure what I have to do in relation to sealing number 5 end cap .and exactly were do I have to use the rtv?and do I have to seal number 1 bearing cap also.?thanking you..
The rear main cap is mostly exposed, tends to seep between it and the block, and/or out the bolts. When we have the rear cap off, put a skin of RTV from the main seal over to the pan gasket, and around the bolt holes. Don't want to effect bearing clearance, so needs to be thin, but doing it drys that area up.
