3F-E Idle problems
Discussion in '60-Series Wagons' started by PurpleFJ62, Feb 28, 2007.
  1. PurpleFJ62
    PurpleFJ62
    509
    Media:
    74
    9
    Nov 23, 2006
    Michigan
    Hi all. My 3F-E idles very rough when in Drive and stopped. Like sitting at a stop light, idle is around 600-700 rpm and shakey like my kibota diesel. The problem seems to get worse as the engine heats uip. When accelerating from a stop the engine is very sluggish between idle and 1500 rpm, after that is smooths out and feels like its firing on all cyls.
    any help would be great.
    -thanks, nate
  2. John McVicker
    John McVicker SILVER Star
    2,272
    596
    Jul 11, 2005
    Big Pine, CA
    If it's not an easy to see vac. leak you might adjust the 'golden screw' & see if that helps smooth it out.
    Turn it very gently cw till it gently bottoms out. Engine should stumble..then start turning ccw. There is a suggested # of turns but I don't remember. Be sure to count the turns cw & if it didn't help you know where to set it back too.
    Remember, as you turn it cw.. do it gently.. seat it softly.
    Good luck, John
  3. euclid
    euclid
    5,985
    Media:
    14
    Albums:
    1
    357
    May 15, 2002
    Jackson, MS
