I saw this on an aussie site to overcome the problem of matching a 3F or 2H gearbox to a 1HZ
The thread is about a 1HZ into a FJ75 (but he actually had been given a 1HD T
Just thought I would pass it on. Some may find that method easier than swapping input shafts or whole gearboxes in future swaps
You can read the rest of the thread here
bainsy's little 75 series - DownUnder4x4
Bainsy
"Phase 4: gearbox.
ok, i had a problem! the engine wont bolt up to the gearbox! thankfully i got onto a bloke who has done these conversions before and supplied me with a HZJ75 bell housing. and as far as im aware, the input shaft on the FJ75 boxes are 10mm shorter and the bell housing was machined 5mm each side to compensate. then for my other problem, the clutch! i wanted a 4-terrain clutch, BUT, they come as a complete kit, and i needed to mix and match. i needed a HZJ75 "clutch kit" with a HJ "clutch", but thanks to the guys at repco they allowed me to do this. the flywheel was machined, clutch installed and the gearbox fitted like a glove. What a relief! the engine and gearbox was mounted on the chassis with a little modiforcation for the engine mounts."
