Alex Waddell
- Thread starter
- #21
Sounds good to me! I hate running out of gas on the trail.
Thanks for the information Curtice. I bought the engine and Cowell harness and am in the middle of tracing out where the wires go. I will definitely be picking your brains as I get into the wiring more.Couple additional thoughts from my experience, if helpful. I've converted one FJ40 to a 3FE, and am in the middle of another.
If you have wiring questions, let me know. I'm smack in the middle of wiring and have dreams of 3FE wiring diagrams at night .
- Brake booster from City Racer fits perfectly, both for the clutch slave and for the 3FE intake manifold. mini truck booster works as well.
- FJ40 radiator works great with the 3FE. But I am not in AZ. For hoses, I found 40 upper and 62 lower works well.
- I used the 3fe mounts up front and the 40 mounts in the rear. I kept the H42 in both cases. On my second one, I am using the AC, so kept that mount/bracket. If you use the rear bellhousing mounts, that will indeed line you up pretty perfectly.
- I didn't shim the engine, rather I re-drilled the mounting holes on the fan shroud to lower it to get it to fit.
- I used an angle finder to get slight angle on engine mount (2 degrees maybe?...can't remember)
- In both cases I used the 3FE alternator. It is internally regulated I believe, so no need for the external regulator.
I had found this in a 3E-E conversion write up here on IH8MUD.The VSS in the speedometer will work with the 3FE ECU.
My 68 didn't have a VSS. It just has a cable the plugs into the speedometer.In my first 3FE conversion, I didn't even hook up the VSS (iirc, my speedo didn't have one for some reason). That has been 8 years and i've had no issues, no CEL or anything. That said, I know others have hooked it up and gone the route you plan to do. I think you will be fine. The ECU would expect 4 pulses as noted above and I think different stock clusters that have the VSS might do different pulses...I think earlier years were different.
