3B water pump qustion??
Always on the Run
Is there a diff in a 3B water pump if it has clutch type fan or not? Is it a big deal putting a clutch type fan on my BJ42 that did not come with clutch being 12V from AUS? I just bought a clutch type fan so I guess I need a clutch for it, is there anything else I will need besides that or is that it?
Thanks
Rob
Thanks
Rob
There is a difference. The pump for the clutch fan has a bigger distance between the holes where the fan bolts onto. A clutch fan will not bolt to a pump not designed for it. I learned that the hard way when swapping out my old pump for a new one. The new one was not designed for the fan, and it did not bolt up.
J
Thank you J
The company that sent me the wrong fan blade is unfortunately the same company I bought the Water pump from. I am just collecting all the parts for my frame off and I am running into problems already
Thanks
R
Thank you J
Thanks
R
Hey,
There is also a difference between powersteering and non-P/S, get the proper one for your intended outcome.
eric
what is the diff between power and non-power steering WP?
The powersteering model sticks out further due to the double pulley for the powersteering belt.
Hola
eric
