3B water pump pulley differences???? (1 Viewer)
Always on the Run
Is there a difference between clutch type and non clutch type water pump pulleys? I went to mount my non clutch type pully on my new clutch type water pump and the holes do not align? seems to be a depth difference as well? anyone with experience with this? I guess I am in need of a clutch type water pump pulley now?
Rob
yes there is a difference, not between 3b, but between B and some 3B, different bolt pattern and different depth
l have a 3B non clutch type waterpump from a 3B engine rebuilt from ENNS toyota,depth and bolt pattern re different.
Simon
Winnipeg
I'm looking for a water pump pulley for a 3b series I any thoughts? Brent
There is most likely a few different types. Stating the year and model along with your locality helps.
It’s most probably with 8 mm fan studs, so the higher version. If it’s 6 mm, it’s the lower.
