- Joined
- Feb 21, 2006
- Threads
- 8
- Messages
- 183
- Location
- Port Stephens, NSW, Australia
- Website
- www.r2clan.com
Haven't started the BJ42 in over 3 months and when I went to start it yesterday to move it up the driveway to go on the flat bed it wouldn't start. I knew the fuel was low so I put 10L in and then cracked the nut on the fuel filter cracked open the factory primer pump and it would leak a lot of fuel whilst pumping.
I also noticed a lot of air bubbles coming out of the primer pump when pumping but it was squirting a steady stream of fuel out still. I couldn't get it to start in the end. Are you suppose to just loosen the bolt in the fuel filter or take it out completely?
I've read a few threads on replacing it with a 126 bosch primer pump but I don't like how they don't lock down when not in use. Has anyone tried to refurbish the factory pump with a new o-ring and a new copper washer?
EDIT:
I just asked our local diesel shop Maitland Diesel Services and they didn't recommend the bosch and only sold the high quality Zexel full steel body primer pump cost $40 AU
EDIT:
