I was doing a Turbo install on a 3B and as part of the process I take some oil pressure readings before and after just for peace of mind.
Anyway, I thought I would post a few pictures as they may help some one out if they are looking for 3B oil Pressures with Turbo etc.
The engine is a 3B with Rotary Fuel Pump running in a BJ46. It has 240 000 km on it
Compression is pretty much 475 across the board and I have drained the oil, removes the sump, inspected everything and then given it new Oil and Filters.
Oil is 15/40 T4
These readings where taken both cold and hot just to show the pressure and also the vagueness of the factory pressure gauge.
Cold Engine 2500 RPM
Cold Engine at Idle
Cold Engine 2500 RPM , 75PSI on the Gauge , Factory Gauge reading
Engine starting to warm, temp gauge just moving, 50 PSI on gauge, engine at idle
Warm Engine , at idle factory gauge makes you want to pull over 30 PSI on the gauge.
I will swap out the 15/40 for some 20/40 just to get it a little higher when warm but it goes to show that the factory gauge can give you a fright when really it is not that bad.
None of this cause the Fuel Cut off to Actuate.
Oil is 15/40 T4
Cold Engine at Idle
