I had a shop install an intercooler on my Fj- w/ 3B turbo'd and I have run into a few problems that I hope I can get some clarity on.
-PROBLEM:I used get boost to about 15psi MAX under acceleration on the flat and between 5-7psi cruising around, now I can barely get 5 psi full throttle and power is obviously down.
-I decided to make this upgrade just after some engine work. I was getting my head gasket replaced (the one that blew was the wrong/old style fiber gasket w/steel rings; now replaced w/ MLS gasket), having a rocker arm replaced, new valve seals, pre-cups, and refurbed the fuel injectors. All of that work was completed and truck was running, but the original turbo (minus intercooler) wasn't test-driven. Also, prior to identifying that I had a blown head gasket I adjusted the timing to the stock match marks from being slightly retarded ...thinking I had a fuel issue (etc etc long story) - (having it retarded: yielded significant gains in low end torque, increased boost, tolerable EGT's [max 1100], and great driveability as noted above where I stated the problem)
Here's what I have done to eliminate variables.
1) I have checked for boost leaks and found none. The system holds pressure, no leaks in the plumbing.
2) Disconnected wastegate to rule out early/excessive wastegate action - still no boost over 5 psi
3) Increased fuel/decreased fuel - no impact on boost; slight increase in power.
What I know about adding plumbing and intercooler:
1) May loose 1-2 PSI because of additional volume w/intercooler and plumbing.
2) Decreased air intake temps and EGT's
3) Added power because of #2 (increased air density)
***this is why I'm puzzled - too much of #1 and none of #2 and 3, and it is simply "worse" than before adding the intercooler***
Next steps I have considered to get back lost power:
1)Retard timing to where it was pre-engine work.
2) Eliminate intercooler and re-set to pre-engine work turbo configuration [sad option as I just paid for this]
3) Drive Landcruiser over cliff - one last burst of speed
I hope someone with more knowledge can offer ideas, consolation, or anything at all to help get the ol cruiser cruising again.
Links to pictures:
Intercooler Pic
Plumbing Drivers Side
Plumbing Passenger Side
Links to pictures:
Intercooler Pic
