John in Utah
Doing glow plugs and a compression check on my 3B since it’s had a harder time starting this winter than last, I found someone had put the wrong plugs in it. The correct Y-147T plugs are quite a bit long than the Y-118T-1 old plugs:
I didn’t think much of it until the #4 plug won’t even catch threads in the hole. It will thread into the other 3 cylinders just fine though. Could this be why someone used the shorter than stock plugs?
Ive read of VW or merc diesels having issues with carbon buildup in the holes and needing reamed out. Could I just dump some diesel down there and hope to loosen any up? I thought the plug goes down into the pre cup so I’m pretty scared about forcing it down in there.
