3B front crank seal
Discussion in 'Diesel Tech / 24 volts' started by duckling, Jul 19, 2005.
  1. duckling
    duckling
    201
    Jun 14, 2005
    Cape Breton, Nova Scotia
    Mine is starting to spray oil on my belts and be a general nuisance. Has anyone ever changed one of these? Service manual says it can be done on the truck. Anything special to get that pulley off? Do I have to drain the oil first? Thanks for any tips and tricks.
    84' BJ60 195 kilometers
  2. duckling
    duckling
    201
    Jun 14, 2005
    Harmonic Balancer size
    So I pulled everything off to expose the front crank seal but the seal supplied by Toyota was smaller than needed. Also, my speedy sleeve to fix the grooved harmonic balancer pulley was too small. Does anyone know the outside diameter of that hb pulley shaft?
    Thanks for any help,
    84' BJ60
  3. duckling
    duckling
    201
    Jun 14, 2005
    Crank seal again?
    I just replaced this turkey a year and a half ago and used a speedy sleeve on the pulley to fix the groove. Now it's leaking again. What gives?
    I need to go in there again over the holidays to pull the rad for a recore so I'm wondering if I need to do the same procedure. Maybe I did't read between the lines for the guru advice.
    Thanks for any suggestions.
  4. brownbear
    brownbear Mod in Hibernation Moderator
    6,842
    157
    Sep 6, 2004
    North West Ontario
  5. crushers
    crushers post ho
    22,189
    206
    Feb 10, 2004
    Tara Ontario
    speedy sleeve = leaking in short order...
  6. duckling
    duckling
    201
    Jun 14, 2005
    Didn't know that. So is the solution to replace the pulley/balancer? I guess that may be cheaper than having it spray welded.
