mallred said:What is the name of of the 3B radiator fan clutch in the part manual I have one but cannot seem to find the clutch.
I know that the fan is the same as the one on a 22R and 2F, is the clutch the same also?
Thanks Myrle
Jan-78FJ40 said:I think it is called a fluid coupling assembly. part number 16210-56040.
hth
j
mallred said:Part # is good but it is showing discontinued here in the states, Cdan seems to think it is no longer availble, Wasn't someone here rebuilding them IIRC?
Thansk Myrle
tlcruiserman said:The fan is NOT the same as 2F fan maybe same diameter but clutch on 2F is larger than on 3B. Do you require a clutch fan? Reason I ask is I sell solid fan replacements if you are interested, I disasseble clutch fan modify it and weld it so it is no longer a clutch fan. PM me if you are interested.
You can also buy fluid and replace the fluid in your clutch and that should also fix it, you should also get new O ring once you remove the old one it will usually not fit correctly again.
Cheers,
Michael
crushers said:if i am reading this right then the fan is "firm" i.e. solid, you can not turn by hand the fan part...
if you can turn the fan easily by hand then you need the fluid to make the turn when required...
can you let me know which one of above it is?
FJota said:What kind of fluid do you run in the coupler?
The fan on my 12HT dosen't seem to engage. Has anyone seen a 24 volt electric rad fan? Would I gain more power by going to an electric?
Thanks
crushers said:or say screw it and run fixed...
mallred said:I am going to change the fluid , but if you were going to go fixed I guess any good aftermarked would work, since turbo is on the shelf for this one and should be on in about a week.
wesintl said:I rebuilt mine, it's not hard. I doubt I would do it again though. I have a hard time believing that the part is discontinued....
Also there are different viscosities of oem oil.
Call ENS and see if they have one.
