Howdy! Harbor Freight has one rated at 1000 pounds for $70, and another one rated at 2000 pounds for $120. I'd get the heavy duty one if it will be moved a lot or mounted for a long time. JohnI'm buying a spare 3B engine. Does anyone know of a solid engine stand that will work with this engine ?
BII, The stands that most of these blokes are talking about are the ones that you assemble/disassemble a motor on, NOT run a motor on. It should be easy enough to make a frame to run an engine on though. Bit of 3x2 box steel and a welder and a dash of imagination.....
