3b engine stand
Discussion in 'Diesel Tech / 24 volts' started by Beast II, Feb 19, 2009.
  1. Beast II
    Beast II
    734
    1
    Dec 23, 2002
    I'm buying a spare 3B engine. Does anyone know of a solid engine stand that will work with this engine ?
  2. inkpot
    inkpot SILVER Star
    13,185
    2,618
    Jan 30, 2003
    All over Arizona
    Howdy! Harbor Freight has one rated at 1000 pounds for $70, and another one rated at 2000 pounds for $120. I'd get the heavy duty one if it will be moved a lot or mounted for a long time. John
  3. Beast II
    Beast II
    734
    1
    Dec 23, 2002
    Cool. I'll cruise over there and check it out. Thank you.
  4. Chang-kuao-lo
    Chang-kuao-lo
    905
    6
    Oct 19, 2004
    Tannhauser Gate
    I gots a H/F 1,000 lb stand and it seemed decent enough, gots an engine crane too it seems to work fine. Second on the 2,000 lb unit, the 3B is a heavy unit. Best guess is ~700 lb.
  5. roalco
    roalco
    686
    6
    Nov 11, 2007
    Vancouver, BC
    I've got a spare B engine hanging on one of the cheap chinese 1000 pounders (harbour freight, princess auto, etc) and it's just fine for engine storage (figure on 600 lb for the engine). A bit on the hard side to get rolling on rough old concrete... and get a BIG bar for rotating the engine on the pivot!!! But the price is certainly right!
  6. Beast II
    Beast II
    734
    1
    Dec 23, 2002
    I'm looking for something that I'll be able to run it on to test and tweak it. Something I can get underneath without worrying about the engine falling on my head
  7. Chang-kuao-lo
    Chang-kuao-lo
    905
    6
    Oct 19, 2004
    Tannhauser Gate
    You mean running running the engine?
    That would be a lot more expensive...
  8. ozwallaby
    ozwallaby
    625
    426
    Jan 25, 2007
    Qld, Australia
    BII, The stands that most of these blokes are talking about are the ones that you assemble/disassemble a motor on, NOT run a motor on. It should be easy enough to make a frame to run an engine on though. Bit of 3x2 box steel and a welder and a dash of imagination..... :cool:
  9. Beast II
    Beast II
    734
    1
    Dec 23, 2002
    Yea, that sounds like a sweet setup. Same dimensions as the frame, boxed with sturdy legs. Then bolt the framework to the floor.
  10. D'Animal
    D'Animal Rescuer of Beagles & Landcruisers Moderator
    21,199
    Media:
    180
    Albums:
    8
    520
    Mar 31, 2006
    Central California
