FloridaFJ80
Roaming Land Cruiser Heaven
- Joined
- Sep 11, 2005
- Threads
- 185
- Messages
- 3,051
- Location
- Ashburn, Va
- Website
- www.landcruiserheaven.com
Hello,
I recently acquired a 1985 BJ70 and am experiencing issues with the EDIC. I have searched on mud for threads explaining similar symptoms and here is what I have done to troubleshoot.
Symptoms:
Hard Cold Start - I have to "pump" the gas a few times while I crank the first time for 2-3 seconds cranking, i stop don't close the switch and crank again this time pumping some more and she then starts up. I hear the relay on the PS foot board clicking. I read on @AlbertoSD build thread where he had a bad contact with a power bar. 1985 BJ70 Story and Modifications I am new to 3B's so any idea where and how I can troubleshoot this.
Day driving: During the day while normal operation it operates with the occasional relay click and the engine hesitation or cutoff then it resumes normal operation. Happens ever so often can be tolerated.
Night driving: Relay clicks every 15-20 seconds maybe less. Only way to drive normally at night is to unplug the relay completely and the funky chicken stops completely.
Troubleshooting:
I read on some threads where the relay clicking could be or is tied to voltage of some kind. Where there could be a bad ground, or bad brushes on the alternator. So I checked all of my grounds (4 of them) and they all look ok, nice and tight not too corroded.
I then checked voltage at the batts I have 2 of them but I am 12v (still trying to understand how they are hooked up).
Engine off: 12.66v Batt 1 (DS) 12.67v Batt 2 (PS)
Initial readings Engine running lights off: 12.88v Batt1 12.88v Batt 2
1st Reading Engine Running Lights on: 12.91v Batt 1 12.93v Batt 2
Reading at alternator 13.35v
2nd Reading Engine Running Lights on: 13.01v Batt 1 13.02v Batt 2
Reading at alternator 13.31v
One thing I noticed was that the relay would click faster with the lights on than with the lights off.
Here is a video of EDIC with the lights on.
I also noticed that this hose is just hanging dont know if the other end is supposed to plugged in some where.
Well I wanted to see if any of the 3b gurus can help. I appreciate in advance your reply.
Cheers
Symptoms:
Troubleshooting:
Cheers
