3B Cylinder oil squirter removal?
Orlando Florida
Ready to have my 3B block worked on and cannot for the life of me figure out how to remove the four oil squirters located at the bottom of each cylinder. The book is real helpfull, it just sais "remove them". Anybody know how these things come out?
Thanks,
-Rob
Easy!!
Clean out the threaded hole in each one and find a bolt (that fits the threads), washer (that fits the bolt but is large enough NOT to go through the socket), nut (to fit the bolt) and a socket big enough to go over the oil squirter and allow the squirter to enter into the socket.
Thread the nut on the bolt, put the bolt through the washer, put the bolt through the socket and thread it into the oil squirter. When it bottoms out in the oil squirter, hold the bolt still and run the nut off the bolt. It'll push on the washer and slowly draw the squirter out of the engine and into the socket.
They are just pressed in so they pull out.
It looks like a bolt so you can orient it correctly once you knock it back in.
