I got tired of patching my intake tube on the Troopy. It was cracked nearly all the way around.
A quick measurement told me that the outside diameter of the small end of the rubber tube is about the same as the diameter of the filter lid.
So I cut the rubber tube short on the engine side to use as a spacer.
Then used #11 SCEET tubing (2 3/4") to connect it up.
www.aircraftspruce.com
SCEET-11 DUCTING 2 3/4" | Aircraft Spruce
SCEET-11 DUCTING 2 3/4" Flexible hose made of two layers of fiber glass and silicone coated with a non-visible steel wire inside the hose wall.
