3B coolant path
MrMoMo
That's not rust, it's Canadian patina...
~Kingston, ON, pero soñando de Panamá
Could someone point me in the direction of a diagram showing coolant flow through the 3B.... I can't find one in the FSM, and search seems to bring up way too many results.
Looking for direction and possible places to tap into it.
Thanks
Yes, I can tap into that, but which side is coolant out and which side is coolant back in...
If you look at the 2 hose connections.....one comes out of the thermostat housing and one comes from the water pump.
The water pump is "inlet" (suction) and the thermostat "outlet" is pressure.
Should make sense when you take a 2nd look at it.
