3B bellhousings
Foam Lake, SK
I know I have two different bellhousings for the 3B. Same bolt patern on both ends but one has a cross member bracket and one does not. Also those out of the 42's don't have the tack sensor.
I know, not what you are looking for... :)
crushers
post ho
Tara Ontario
are you sure that the one with the frame mounts on it is for a 3B? the only one i have seen like that is the 77-78 B series engine BJ40...
cheers
Wherever the truck stops!!
Basically what I need to know is when I get my 3B down here it will be from a Dyna or a Coaster. I'm going to the wrecker tomorrow to get an H41 because the Dyna tranny I'm told is not 'Cruiser compatible. When I get the tranny, should I also get the 3B bellhousing? I assume the "B" and "3B" bellhousings have the same bolt pattern if that's what the tranny ends up coming from.
