I'm currently doing some work to my cooling system and wanted to check if anyone has an idea about the following:
I am thinking about plugging a water inlet that goes to the lower thermostat housing. I think it would have been originally part of the heater system? As I don't have a heater and don't plan on plumbing one in soon, I was thinking about plugging the water return line. It comes out pre water pump, runs through a short fitting and then back in above the bottom of the thermostat... does that make sense? You can see what I'm talking about in this photo below: I would plug the red circle on the thermostat lower housing, and move the water temp gauge in green to the bottom where the brass fitting currently is. Basically, this would mean that that small loop would be deleted. Currently, it seems that the 'loop' would always be circulating cooler water (pre pump) directly into the body of the thermostat between the top and bottom... that seems counter-intuitive to me? Shouldn't water coming directly from the head/block determine the opening and closing of the thermostat?
The following is the lower thermostat housing and I am considering blocking off the upper left threaded inlet. The second inlet with a thread is for a temperature gauge. Therefore, the only water going to this before the thermostat opens would be from the head/block... any ideas?
