35's on an F
Discussion in '40- & 55-Series Tech' started by tlcgear, Jan 26, 2004.
  1. tlcgear
    tlcgear
    77
    Oct 21, 2003
    I am doing a SOA and want to run 35's, will be installing a dual T-case system form inchworm gear, but I have an F. anyone running 35's on an F ? if so, how does it do on the road and the trail.
    - Thanks.
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,384
    Media:
    17
    Albums:
    1
    759
    Oct 1, 2003
    MN
    Ran 33's and 35's with an F engine for years. Works fine both on and off road. It will not win any stoplight races on the street, but if you are doing that with a Land Cruiser and an F engine, you need your head checked...
    Good luck!
    -Steve
  3. hammerhead
    hammerhead
    1,995
    2
    Jul 5, 2003
    Central, Utah
    One of my neighbors has a couple Fs over 33s and says it's fine. Like Steve says it's no drag racer but I'm sure you already know that.
  4. 73cruiser
    73cruiser
    39
    Mar 11, 2003
    Southern Ohio
    I run 36's on my 73 with F motor and have no problems.
  5. Archengine
    Archengine SILVER Star
    291
    Nov 6, 2003
    Frankfort Ky
    I run 35's on my F and it does suprisingly well. An F in proper tune should make nearly as much power as a 2F. It's a great engine. I can ride my torque up hills in 4 lo without applying throttle. And I can acelerate quick enough for my intended purposes. I can pass well on the highway, and have no complaints, for what it does, it does well. Going through the mountains with my 3.70's I always have to downshift, but it gives me more time to take in the scenery! FYI though, I'm not stock, but give it a good tune up, and I would suggest some 4.11's or higher, as I'm going that route myself soon.
  6. tlcgear
    tlcgear
    77
    Oct 21, 2003
    Thanks for the help. And I wasn't planning on racing anyone :D
  7. Mace
    Mace rock scientist.. Staff Member s-Moderator
    21,474
    1,930
    Feb 17, 2002
    Las Vegas
    What gearing you planning?
  8. tlcgear
    tlcgear
    77
    Oct 21, 2003
    I'm planning installing a second transfer case . Here is what they say in their website.
    "The Inchworm double transfer case adapter adapts the gear reduction box from one Toyota transfer case to the front of a second Toyota transfer case. The two gear ratios multiply to give you 2.28 x 2.28 = 5.2:1 with both cases in low. This translates into an 83:1 low range with the Inchworm double transfer case adapter as opposed to 36:1 in a stock truck. The adapter plate is machined from solid billet 6061 T6 aluminum and the coupler shaft (not shown) is machined from a factory output shaft. The adapter plate and extra Toyota reduction box (sold separately) together are about 6 3/8 inches long, so driveshaft length modifications are required. An extra hole in the floor of the cab is also necessary to make room for the 2nd stick."
    And accoding to them you don't have to modify the drive shafts. installation instructions http://www.inchwormgear.com/htmlonly/instructions/instructions.htm
    http://www.inchwormgear.com I'm working on developing a more user friendly site for them.
    - Rico.
  9. CruisinGA
    CruisinGA
    6,168
    16
    Mar 27, 2003
    Georgia Tech
    33's on a old tired F with a 3 spd, no problem, can do 75 down the highway all day, and around town is not bad. 35's couldn't be much worse, especially if you happen to have a 4 spd.
  10. tlcgear
    tlcgear
    77
    Oct 21, 2003
    [quote author=CruisinGA link=board=1;threadid=10638;start=msg95774#msg95774 date=1075174395]
    [/quote]
    Nope, just a 3 speed.
  11. sambudo
    sambudo
    120
    Jun 24, 2003
    Wheaton, IL
    35's all day no problem! On the road going up hill, you will need to down shift. Over all not bad. Off road, they work well!
  12. Mace
    21,474
    1,930
    Feb 17, 2002
    Las Vegas
    [quote author=tlcgear link=board=1;threadid=10638;start=msg95726#msg95726 date=1075169332]
    - Rico.
    [/quote]
    This is for a minitruck tcase...
  13. DenverCruiser
    DenverCruiser
    583
    40
    Sep 30, 2003
    Woodstock, GA
    "33's on a old tired F with a 3 spd, no problem, can do 75 down the highway all day, and around town is not bad. 35's couldn't be much worse, especially if you happen to have a 4 spd."
    Holy crap, my F must really be in bad shape then. I have major power problems with hills on my 33's.
  14. Outback
    Outback
    606
    Sep 17, 2003
    Edmond, OK
    CruisinGA....
    How in the hell do you keep that "F" together at 75 mph!!??!! Better question yet...
    HOW MANY RPM ARE YOU TURNING AT 75 MPH !!??!!
    I'm running 33's on my very fresh '72 "F"/3spd/4.11's and am turning ~2800 RPM at about 60+ ish MPH(via GPS). I was told that extended time spent at above 3000 RPM was not good for the "F" series engines. I figure I would be turning closer to 3500 RPM to do 75!! Not good.
  15. Archengine
    291
    Nov 6, 2003
    Frankfort Ky
    I'm at around 2800 rpm at 75 mph with 35's and 3.70's. I like to be able to go 75 on the highway, so I need to get an overdrive when I get my 4.11's, oh and power steering.
