33X10.50 vs 33X12.50
lovetoski
OK, I've got some new (to me) wheels (15X8) and will put rubber on them soon. Lots of tire threads of course, and I think I've read all of them...but I wanted to see if I understand all the differences between a 10.50 and 12.50...
10.50
Better gas milage
Better in rain, snow, ice
Tracks straighter
12.50
Better in deep snow & sand
Better in deep mud
Better in rocks
Did I miss anything? (Besides aesthetics - just looking for functional diffs)
I do have one question - given the same rim, will there be a stability difference between the two? I assume the mounted 12.50s will make the truck ~2" wider. Will this make a difference, on the road, or aired down off road?
Thanks for the help.
Hamilton, MT
I am not sure that the width will make you more stable. Your overall speed in combination with your inclination will have more to do with that. I like the 10.5s but I really think it's going to be preference. For me 10.5s are cheaper and are a bit better on regular trails and snow. Gas milage? I'd ahve to see the numbers but I'm guessing .5mpg difference? Oh yeah and about the biggest reason of all is the price difference. 10.5s are about 40$ a tire cheaper on average!
Good luck.
VTCruiser
Tacoma, WA
i have 12.5 on my 15x8 and don't have any complaints. Aside from gearing, there have been no major differences in handling from the 31x10.5 i had before. I think my mpgs when down by less than .5 from the 31's.
peepers
lovetoski said:
10.50
Tracks straighter
not always the case. if they are set up correctly you will not experience too much tracking on the highway or on worn road. the tire tread on a/t's is aggressive enough that it wont follow the road too much. the difference here between 10.5 and 12.5 is negligable.
lovetoski said:
12.50
Better in deep mud
you have this opposite. the 10.5s will be better in the snow and mud. the sand will go to the 12.5s but the thing about mud and snow is you want the tire to dig and dig and dig until it bites. oh, i just looked up and saw "deep". how deep are you talking here?
by the way... if you are thinking A/T tires it won't matter how deep the mud is once this happens: http://fj62.net/images/mud.jpg
San Rafael, CA
So what's the general consensus here? Who's on 10.5's that wish they had 12.5's and vice-versa...?
I'm about to purchase rims and tires (currently on 31 x 10.5's) and can't decide between the two widths.....Just when you think and extra inch won't matter. I guess I won't be asking any of my female friends : )
Ah hell, maybe I should just get the 32 x 11.5's....
Hamilton, MT
I started out stock then 30's, 32's, and now 33's. Every time I have gone bigger I think why didn't I do that the first time? Go big or go home!
10.50's get me vote for the reasons above. Should note that i never drive on sand and have experienced some drift on finer gravel roads on frineds 12.50's (Dodge truck though). It was unsettling enough for me to think twoce about increaded surface area under the rig. I guess I want more lbs/cubic inch.
TOY350
#1 Super Guy
Grants Pass, OR
My preference is 33X10.5 which I ran then switched to 35X12.5. I think the 33X12.5s look too wide for the height, but that's just my opinion on "looks". The 33X10.5s were much too small for my SOA rig but look good on a SUA one.
Timoss
I've had both and I think in terms of mud vs. snow vs. sand, etc., tread patterns will have more of an impact than the difference between 10.50 and 12.50. For instance, my siped 12.50 MTRs are as good or better than my 10.50 BFT ATs were on road in snow, mud, and rain--that goes for on and off road (have not tried either on sand so I can't comment there). So I'd say when considering performance on surface type, the treads, not the width, will be by far the most important, defining factor.
However, there are a few differences that will be apparent regardless of tread: You will in theory be able to air down the narrower tire a bit further without bopping a bead. The wider tire will catch grooves a bit more on the road (not that much, but noticeable). And the wider tires may be more comfortable on road (more cushion). This is all based on a BFG 10.50 VS. MTR 12.50 comparison. YMMV.
Tim
88 fj62 TLCA
Doc
Utah
Not my experience. A Wider tire on the same size rim will air down further and hold a bead longer than a narrow tire. The wider casing on the bigger tire will exert an outward lateral pressure on the tire bead allowing you to air down farther and maintain the pressure needed to keep the rubber in the bead.
"Poor man's bead locks".
VTCruiser
Tacoma, WA
here is a pic of my 33x12.50's on 15x8 wheels. because of the narrower wheel, I don't think they look too wide, but 12.5 is as wide as i would go for any size tire.
lovetoski
lovetoski
3puttcop said:
Why not run a 32 x 11.50?
Good question...hope this makes sense...I like the rubber overdrive I get w/33's on the highway (which I have to do a lot). I was trying to get a practical sense of the difference between extremes...most agree that 9.50's are too narrow (what I have now) and 12.50's are pretty much the widest most run...so I thought it would be good to get some advice about a "reasonable" choice, 10.50 vs 12.50. That said, I'm not opposed to 32X11.50 per se (doc and others seem to like them alot).
Tire decisions are a funny thing. In the greater scheme of things it's not that expensive...but there is some ego involved in having made the wrong choice. I absolutly hate being wrong...and having to admit it publicly (by buying different tires) just makes it that much more irritating.
What gears do you run with your 32's?
Tinker
Larkspur, CO
Wider tires are better for sand, not snow. I got stuck in my driveway (7% grade) last fall in my '84 with 10.50x33 MTRs in a deep, heavy snow. The PO had 12.50s on 10" aluminum rims which I chucked for 8-inch steelies, so I thought I was going narrow enough to bite through the snow. Guess the tread pattern doesn't provide enough edges for good snow traction. My '83 with stock Wrangler 30s went right up.
MTRs are useless in wet, heavy snow unless they're siped (thank you Discount Tire for the freebie after I got stuck).
If you truly love to ski, you love to get there & back. Look into tires with better snow traction.
Doc
Utah
FWIW- mine are 33x11.5's. Not 32's. On a 16" rim though too...
lovetoski
Tinker said:
MTRs are useless in wet, heavy snow unless they're siped (thank you Discount Tire for the freebie after I got stuck)..
How do you like your MTR's siped? I've done this on both my cruisers (and like it alot) but neither of them have mud tires.
...and you're right that getting to and from the mtn is a key part of skiing!
North Florida
I am running stock gearing, which I think is 4.11. They seen like the perfect rubber O/D to me. Much of my off-road is in very soft sand and the slightly smaller diameter but relatively wide tire seems to just float well.
Timoss
My MTRs are siped also. They are as good as BFG A/Ts on the road in rain and snow (this is in the Northeast). I was pleased with that performance. Never had MTRs not siped, so I don't know how they perform "stock"...
Tim
88 fj62 TLCA
