Will a 35s fit in 91 land cruiser with a 3 1/2 inch lift with out rubbing?
Wow thank you, will there be no issues or rubbing? Just wanna make sure, tnxYes, 35’s will fit with a 3 1/2” lift.
35x12.50x15What tire size are you planning to run? 35/12.5R16?
I'm planning to run 35x1235x12.50x15
Those are fairly thin tires, which will help you. If you stay with stock rims or stock back spacing with different wheels, you will be good. You may need to increase the rear bump stops by 1”.
check this thread for more tire info.
Which Tire is right for me? - FAQ Tire Information
This is probably the question that goes through each cruiserheads mind on multiple ocassions. Tire's cost a lot of money and you want to make sure you get the perfect set of tires for your hard earned cash. The problem is what's perfect for you, is not what's perfect for others. How do I...forum.ih8mud.com
Those are still the 33s that I have, I'm still thinking of which 35s to buy, any suggestions pls!The new tires look great!! How do you like them?
Those are ultra rims but I don't know the exact size of itThose are still the 33s that I have, I'm still thinking of which 35s to buy, any suggestions pls!
Sorry, what are 853J and 863?Yes, I am running OME 853J and 863 with 30mm spacers front and rear with 315/75-16 KO2.
Sorry my OME lift consists of those springs. Those are the OME part
I'm still thinking of which 35s to buy, any suggestions!Sorry my OME lift consists of those springs. Those are the OME part numbers.
Any rubbing when you turn and no vibration on the highway?I just went from 31s to 35s (35x12.50x15 BFG KM3s) on stock wheels and 3” lift on my 92. Rear tires rub a bit on frame when flexed. Didn’t notice any other rubbing, but haven’t done any hard wheeling either. Looking for options other than spacers.
