33"s = over active ABS?
Discussion in '80-Series Tech' started by parabola, Oct 25, 2005.
  1. parabola
    parabola
    316
    Jun 27, 2005
    Austin, TX
    I've owned this truck since June and not once has the ABS been activated. Now, after the 33" Revos, it seems like if I brake and hit any sort of bump the ABS will kick in. I've had these tires about a month and the ABS has activated at least half a dozen times since then in the same sort of situation. Not severe braking but braking over rough surfaces.
    Anyone notice this or is my rig or the driver insane?
  2. alaskacruiser
    alaskacruiser
    1,619
    21
    Mar 30, 2003
    LA, CA
    parabola- I didn't correlate my identical problem with the tires, but now that I think about it, mine also started after I switched to the 285 Revos. Same problem on same tires with a '97 LX here, too.
  3. Rich
    Rich
    1,805
    6
    Jun 16, 2003
    Check air pressure and shocks. Heavier, stiffer, tires, espescially in combination with worn shocks, could more easilly loose contact with road. If tire looses contact with road while braking, and therefor slows quicker than the other 3 tires, then ABS can kick in.
  4. e9999
    e9999 You want to do what...? Moderator
    16,737
    593
    Sep 21, 2003
    US
    fwiw, no such problem with my 33" MTRs
  5. Rich
    Rich
    1,805
    6
    Jun 16, 2003
    Neither do I.
  6. alaskacruiser
    alaskacruiser
    1,619
    21
    Mar 30, 2003
    LA, CA
    I have a theory that this is a problem unique to the LX's softer suspension. LX owners please chime in!
  7. parabola
    parabola
    316
    Jun 27, 2005
    Austin, TX
    The OME HD kit is about 3 months old so I doubt the shocks are the issue. I'll double check the tire pressures; maybe the tire place inflated the hell out of them or something.
  8. parabola
    parabola
    316
    Jun 27, 2005
    Austin, TX
    my springs/shocks are the OME HD so I don't think that is it for me. I'd definately not describe my suspension as 'soft'! :)
  9. cruiserdan
    cruiserdan SupportingVendor Emeritus Moderator
    22,749
    7,635
    Mar 27, 2003
    Land Cruiser Heritage Museum broom closet
    I bounce back and forth between stockers and 33's on heavy steel wheels. there is a 35 lb difference in weight as well as the diameter change. I have not noticed anything odd.
  10. TX_TLC
    TX_TLC
    1,480
    9
    Apr 29, 2003
    Texas
    Might chalk it up to coinsidence...that is what mine started before I lost a front ABS sensor.
  11. RavenTai
    RavenTai
    6,048
    48
    Nov 16, 2003
    Dixie co. Florida
    My 2500HD Silverado did this, it had stiff "D" load range tires (245/75 Firestone Steeltex IIRC) at 50 PSI, the door sticker said to use 80 PSI on the rears but I never did carry enough weight to warrant such,
    But anyway there is a particularly short in town freeway exit that has very lumpy asphalt at the end, the abs would kick in just about every time on these bumps,
    Seams to support stiff tires and too much air makes for poor road contact, that or Bridgstone/Firestone does not know how to make a good tire. :flipoff2:
    The LX does not do this at this exit, either with the worn out original shocks nor the new Bilsteins, tires are 265/70 Michelin LTX (po's choice not mine)
    About the only time I remember ABS kicking on my 80 was in was a panic stop and onto shoulder evasion induced by a idiot in an F-150.
  12. BigMac
    BigMac SILVER Star
    216
    2
    Mar 27, 2003
    Lompoc, CA
    Nope
    I have over 40K on my 285 Revos (w/OME suspension) and have never had unwarranted ABS chatter as described. ABS does work, but the need arises very infrequently. I run about 35psi. HTH, BigMac
  13. Cruiser Clint
    Cruiser Clint
    446
    Media:
    1
    Albums:
    1
    Jul 4, 2004
    Indianapolis, IN
    I had the ABS chatter a while back and I never really thought about what might have caused it. It developed right after I installed my 285's too. I am running a little lower air pressure than I used to and now that I think about it the ABS chatter has gone away. Before reading this post I never gave it a secnd thought since I assumed it was the nature of the brast. Weird! ;)
    Clint
  14. davegonz
    davegonz Keeping it Weird SILVER Star
    8,251
    Media:
    17
    Albums:
    3
    2,499
    Sep 15, 2004
    Austin, TX
    Josh,
    I run 33" Nittos and also run the OME HEAVY lift..I have never noticed the ABS come on. Could it be LSPV related? Did you adjust it when you installed the lift? Don't know...HTH.
  15. Bear80
    Bear80
    3,019
    Media:
    12
    Albums:
    1
    71
    Sep 23, 2004
    I've never noticed the ABS activate until I also upgraded to 33" tires. I only feel it under firm-hard braking over bumps/potholes/uneven pavement. I think the road combination and a larger tire makes the ABS activate sooner than with stock tires.
  16. -uhuru-
    -uhuru-
    197
    Media:
    3
    11
    Aug 9, 2005
    Panama
    ABS sucks ... disconnect that joint and just drive her old skool ... remember those analog brakes... my shizzle went crazy after i fit them 37's up in there ... just unplug it and be done with it!
  17. parabola
    parabola
    316
    Jun 27, 2005
    Austin, TX
    No, I didn't adjust it. I wonder if that is it...
    I did perform the "240lbs of concrete in the cargo area" modification today to see if it helps my Grrrrr, so we'll see if it changes anything over the next week or so. :)
