32X11.50 BFGs on Stock Rims?
Discussion in '60-Series Wagons' started by FJ60-Hokie, Aug 29, 2006.
  1. FJ60-Hokie
    FJ60-Hokie
    196
    2
    Jul 5, 2005
    Coastal Virginia
    Can I safely run 32X11.50 BFGs on STOCK Rims with a 2.5 OME lift?
    This will be a temporary solution until I can get the cash to buy some rockcrawlers, but I have an imediate need for new tires.
    In searching threads I didn't recieve a difintive answer on this question and am ready to pull the trigger on a set.
    Thanks for the help fellas!:beer:
  2. bundy18
    bundy18
    120
    Aug 3, 2006
    Lincoln, NE
    don't know for sure but i would say yes, go ahead and get them because i don't see a problem with it. i have ran 35-12.5 on 15x8 rims with absolutely no problem, also currently have 284/75R16 (~33x11.5 measured) on my factory 97 chevy rims and have beat them to death with no regreats
  3. cullmancruiser
    cullmancruiser
    204
    3
    Mar 28, 2005
    Cullman, Alabama
    That's exactly the setup I'm running on my 62 with no problems at all. My tires are about wore out so when I replace them I'm going with 33 x 10.5 tires on 15 x8 Rockcrawlers. I really like the way that combo looks.
  4. zcruiser
    zcruiser Needs monitoring
    1,205
    12
    May 7, 2005
    Hillsborough, NC
    Pretty much what I've got too. I've had no problems.
    [​IMG]
  5. RedfishBluegrass
    RedfishBluegrass
    551
    Albums:
    1
    1
    Apr 21, 2005
    Charleston, SC
    I am also running the same! No problems here.
  6. FJ60-Hokie
    FJ60-Hokie
    196
    2
    Jul 5, 2005
    Coastal Virginia
    Thanks guys! :beer:
    I have read some negative things about gearing when going with 33s. I went that route would it affect things like going uphill?
  7. zcruiser
    1,205
    12
    May 7, 2005
    Hillsborough, NC
    Yah, you lose a little torque at the wheels (if that's the right term), and really need to gear down to make it right.
  8. CSA
    CSA
    606
    14
    Nov 15, 2003
    Lots of tire stores will not install a 10.5" wide tire on a 6" wide wheel much less a 11.5" tire on a 6" wide wheel. The tire is, IMHO, too wide for the stock wheel. Lots of people will disagree, but I tend to believe that BFG's engineers know what they are talking about when they specify a wider wheel.
  9. FJ60-Hokie
    FJ60-Hokie
    196
    2
    Jul 5, 2005
    Coastal Virginia
    My plan is to run them for the short term until I can put together the greenies to pick up some rockcrawlers and I would like more size than the 31s.
  10. rockyklg
    rockyklg
    198
    Apr 21, 2006
    south fl
    same setup here... works fine but i would go wider if i could. i think the narrow rim sort of rounds the tread a bit. my .02 :beer:
  11. chicago
    chicago
    9,628
    Media:
    21
    Albums:
    1
    50
    Jan 18, 2006
    Reno, Nevada
    Summit carries 15x8 us wheel (black steels) for 40 bucks a piece...I donno if youre interested or not, but theyre cheaper than "rock crawlers" and look about the same.
    Chicago
  12. FJ60-Hokie
    FJ60-Hokie
    196
    2
    Jul 5, 2005
    Coastal Virginia
    Thanks for the heads up.
    What is really the difference between rock crawlers and black steel wheels.
    If I can ride out the stock rims for a few months I should be able to save for the rockcrawlers.
  13. frank boone
    frank boone
    18
    Jun 12, 2006
    I have 33 12.50 15's on stock rims with no problems at all. I painted the wheels flat black and it looks tits. I plan to go wider on the wheels but for now it works....and the chicks dig it.
  14. chicago
    chicago
    9,628
    Media:
    21
    Albums:
    1
    50
    Jan 18, 2006
    Reno, Nevada
    As best I can tell, its the name. Initially, I was looking at the rock crawlers, till I saw the summit steels. Im a cheap bastard though. The look good, theyre cheaper...thats what I got!
    Chicago
  15. FJ60-Hokie
    FJ60-Hokie
    196
    2
    Jul 5, 2005
    Coastal Virginia
    Cheap is good!
  16. DirtyLittleSecret
    DirtyLittleSecret
    1,398
    Sep 21, 2006
    WA
    Q: what's our bolt pattern, and will 15x8's still snug under the wheel wells?
  17. RredFJ40
    RredFJ40
    1,360
    26
    Nov 1, 2003
    Klamath Basin
    A: 6 on 5.5", and I can't answer the other.
  18. DirtyLittleSecret
    DirtyLittleSecret
    1,398
    Sep 21, 2006
    WA
    Thanks. Im assuming its also 3.75" backspacing?
  19. philos1
    philos1
    1,593
    1
    Feb 8, 2005
    the valley, yeah that one
    why not 33X10.5 or 9.5???? work great on stock wheels, and you can also have your stockers powdercoated black $25 Ea at les schwabb tire stores IIRC...
  20. philos1
    philos1
    1,593
    1
    Feb 8, 2005
    also, 33 chains, spares, etc are usually more common as well...
    my .02
