325 Tires
Discussion in '80-Series Tech' started by Trunk Monkey, Jul 27, 2005.
  1. Trunk Monkey
    Trunk Monkey Moderator
    9,038
    1,656
    Apr 27, 2003
    Salt Lake City
    Just noticed that Procomp is making 325/80R16 tires in all their models. This equates to almost a 37" tire. Thing is, they're WAY more expensive than any other 16" tire. The 315s are around $220 ea. and the 325s are $360 ea.
    I remember when the Hummer sized MTRs were twice as much as normal, why would the 325s be so much more?
    I guess it doesn't really matter, it's not like I can fit them with a J lift. Maybe for those of you with Slee's 6"?
  2. SHarr5184
    SHarr5184
    18
    Jul 24, 2005
    Marietta, GA
    I personally haven't tested the ProComp on a vehicle of my own, but I haven't heard great things about the ProComps...this was coming from a guy that works at Southern Off-road. Does anyone run them and have an opinions?
    Steve
  3. NorCalDoug
    NorCalDoug problems solved daily...
    6,294
    120
    Oct 27, 2003
    uhhhh...duh...Northern CA
    supply & demand?
  4. stinkyfj60
    stinkyfj60
    1,344
    3,394
    Apr 22, 2004
    Roodepoort, South Africa
    I have heard that the Pro Comp X-whatever it is sucks... Doesnt clear the voids in mud or snow but does ok in the rocks.
    But I have heard the Mud Terrian is ok. Dont know anything about wear issues though...
  5. dmc
    dmc
    687
    Media:
    5
    Albums:
    1
    295
    Apr 6, 2004
    Wandering the Western Hemisphere
    Why are you even debating? Didn't you make up your mind on tires already?
    dmc
  6. CreeperSleeper
    CreeperSleeper Cascade Cruisers SILVER Star
    6,865
    700
    May 16, 2005
    Forest Grove, OR
    I used to run ProComp M/Ts and I liked them better than the BFG M/Ts (KM) I had before them. Now I'm going to try the Trxus M/T from Interco. I'll let you know how I like em.
  7. Trunk Monkey
    9,038
    1,656
    Apr 27, 2003
    Salt Lake City
    I know, just throwing out an option for a bigger tire and be able to keep the stock 16" rims. I was telling CDan the other day that between you and him there's going to be a bunch of Dunlop converts.
  8. stuck in GA
    stuck in GA
    736
    Jan 10, 2005
    Farmville, VA
    Yeah procomps suck. I had the mt's and they wore fast and didn't do that great in the mud actually. 4wheel parts pushes them though because procomp is 4wheelparts main dealer.
  9. Bear80
    Bear80
    3,019
    Media:
    12
    Albums:
    1
    71
    Sep 23, 2004
    I have never run mt/r's or bfg m/t's. I think the mt/r looks like crap, might work great but a tire can only get you so far. The bfg m/t looks good to me and has been used enough to prove it's worth.
    Pro Comp X-terrains look the best to me and every set I've run have been super smooth. Of course they have been roadmatched when mounted. The only down fall I can see in the x-terrain is the lack of lateral grip in such things as snow which I have never encountered. I've run Mickey Thompson bias ply tires in the past and never noticed any loss by using x-terrain radials now.
    SOO SEXY....for a tire :D
  10. stuck in GA
    stuck in GA
    736
    Jan 10, 2005
    Farmville, VA
    It looks like a street tire on steroids that went bad. I am sure they are fine out west but here in the mud they suck. Guy in Georgia Cruisers has them and doesn't like them.
  11. Bear80
    Bear80
    3,019
    Media:
    12
    Albums:
    1
    71
    Sep 23, 2004
    Why would someone even consider a directional tire for mud.....red neck inbreeding cloud their mind?? I agree probably not the best for mud and snow but that's inherent with a directional tread.
    Sidewall srength...comeon I've watched a guy slash a bfg mud terrain over the same pice of tree stump I rubbed aginst. Like I said a tire can only do so much. If you need more side wall strengh than what the x-terrain can provide you really shouldn't be on a radial tire.
    Back to the topic though. I'd agree with demand but also market analysis. It really blows my mind that a tire for a 18 inch wheel cost so much more than the same size tire on a 16 inch wheel. How can less rubber = higher price?? Can't really say low demand in this situation because almost all new trucks and suvs come with 18 inch wheels.
  12. Josh83
    Josh83
    764
    1
    Nov 26, 2003
    Frankfort, KY
    Procomp tires suck. 4wheel crack whores pushes them because they OWN procrap. A buddy of mine had the MT's and they wore like crap and didn't clean well. As far as side wall strength, saying xterrains are better than BFG MT's isn't saying much. If you want a radial with sidewall strength, go with IROK's(wear quickly in radial flavor) or PJ Dirt Grips(probobly the best radial on the market durability wise, but mucho $ and heavy). Xterrains are by no means the be all end all for radial sidewall strength. You should all buy swampers and be happy.:D
  13. Bear80
    Bear80
    3,019
    Media:
    12
    Albums:
    1
    71
    Sep 23, 2004
    Just shows how much you know.....pro comp tires are made by either cooper tire or kelly springfield, I can't remember which. In no way does 4wheel parts OWN pro comp.
  14. Josh83
    Josh83
    764
    1
    Nov 26, 2003
    Frankfort, KY
    Don't get all butt hurt cause I dogged out your tires. 4Wheel parts owns Explorer Procomp, Steel Horse and Genuine Steel. As for cooper or kelly making PC tires, they have these things in business called contracts. "I'll pay you $X to make tires and put my companies name on them"
  15. nyk438
    nyk438
    253
    Jun 23, 2005
    Austin, TX
    "butt hurt" Not even going to get started on that. Got a friend who runs XTerrains, sexy looking tire and the best on that Pro Comp makes. There MT's are the biggest waste of rubber I've ever seen. Friend bought a J**p with them on there and wore to crap in 3 mos. Now he is trying to sell them too me for 100 bucks for 4 tires, well really 3 since one is shot to s***. XTs are good tires, not so great in mud but nice tire.
  16. Trunk Monkey
    9,038
    1,656
    Apr 27, 2003
    Salt Lake City
    Really wasn't trying to start a thread on the merits of Procomp and if they suck or not. I just hadn't seen that they have the 325/16 size out. The only other tire I'd ever seen in a 325/16 was a Michelin XZL.
  17. ginericLC
    ginericLC Wagon Wheeler! SILVER Star
    7,426
    466
    Jan 29, 2003
    MH, IDaho
    One problem you might encounter is that the tires don't really exist. I was going to give the Pro Comp Xtreme AT a try. Supposedly a good sidewall in an AT tread. I was going 315/75/16s and when I placed my order I got an email back that they were on backorder. I called to find out when. Supposedly they will make the first bunch in late Oct. or Early Nov. but the salesperson said they might not be out until April of the following year realistically. I saw this tire in a different size when I was in Oregon. It looked plenty beefy. It is more open than it appears in their ads. I was looking at a 37" on a 17" rim. The Pro Comp MTs and ATs are more when you add the road hazard than BFGs are locally for me. Plus I don't have to hassle. I drive to the tire store and get them balanced and replaced. None of this waiting on hold or waiting on a tire for days.
    I have Iroks on my 40. I would not recommend them to anyone who drives a lot the rubber compound must be similar to a BFG Krawler because they don't last well. The TRXus has bad reviews for wear and for balancing. I've seen a few sets that chunked really badly. Maybe driver error but I've seen more than one set. For a radical radial I think the TSL Radial is the way to go. Tough sidewall and better wear characteristics than the Irok.
    MTRs seem to have this legendary sidewall for MT tire, but I watched two of them get ripped in the sides within 10 feet of where I just climbed with my BFG MTs. Luck has as much to do with sidewalls as the strength. They also seem to wear decent. I would have probably purchased them had the 315s not been on backorder for so long.
    I could personally wreck a solid rubber tire. I have that sort of luck. Probably I'd wreck a solid steel tire too. Our lava rocks shred tires. Although I've never seen them shred any TSLs.
    I ended up with a really blah tire. The BFG AT in a 315. It sucks at everything except highway. But since my 80 sees a lot more highway miles than anything else I'm happy. Plus I have roadhazard. So I'll be getting new tires after every 4th wheeling trip. It is OK. I have a spare. I've been considering picking up a second spare. Then I'll be set for my tire wrecking expeditions.
  18. Bear80
    Bear80
    3,019
    Media:
    12
    Albums:
    1
    71
    Sep 23, 2004
    I really don't care if you dog my tries. To each his own, but I really don't think 4wheel parts "own" Explorer Procomp. Even if it was a parent company, 4wheel parts is actually a subsidy of another company which I cannot recall. Bottom line 4wheel parts has no "real" say or development with Procomp products.
    I agree 4wheel parts is a crap hole but I still buy a few things from them and even tires. When it come right down to it, they are local to me and offer the cheapest price and I really have never had a problem with the place or somthing I've bought from them.
    For tires, the maker as you so cleverly pointed out are contracted. But if you knew anything about tires, you'd know that there is only a few rubber/tire companies. So most brands are not made by the company that the tire is sold as. So I would like to know how contracting out to another company makes the procomp tires a representation of other procomp quality and comes back to 4wheel parts??
  19. concretejungle
    concretejungle
    9,592
    804
    Oct 27, 2003
    North Cadillac
    I think a directional tire for mud is an excellent choice so long as you are not sliding on a side hilll. Just look at the videos from venezuela and the mud down there, a directional tire such as a super swamper bogger would be awesome in that stuff. Like paddles pushing you through. I have heard the Xterrains perform very well on rocks, but that's about all i know on them.
  20. LICruiser
    LICruiser
    184
    Mar 23, 2005
    New York, New York (LI)
    Just to let everyone know Procomp is owned by the same company as 4wheel parts. The parent company is called Trans America Auto. I'm i finance and we are currently doing a deal with them. They basically want to open a ton of new stores around the country. At the bank meeting they pushed the pro comp tires lie they were the best. I know better.
