32 yr old bolts wont budge =o(
Thanks to the awesome comeraderie of this board I was able to find some replacement windshield hinges for my fj40. Having a hell of a time getting the bolts that go from the hinge to the tub to budge, have doused with Mr. Wrench with no results...as soon as i apply generous amounts of force the bolts begin to strip so i stop for fear of completely stripping them out. Any tricks of the trade on removing such bolts?
TIA
kj
Take your time
I know you want to get those new hinge/plate things on there, but take your time.
The threaded portion those bolts go into are in a floating plate inside the windshield frame and vehicle, and I can imagine it would be a beotch to fix them if you damage them or break off a screw in them. Soak them, and use the impact tool idea. I had to do that on mine the first go-round. Good luck.
I soak mine in PB blaster for a few hours, over nite if possible, sometimes still a little tough but they almost always back out.
i just bought some of these.....and yes an impact screwdriver works, another idea is to whack a hammer on the back of a metal shanked screwdriver, and a wrench on the shank of the screwdriver,so now, its like a poormans impact....then again, i had to use an air hammer (or a poor mans chizel) to get two of mine off.....heres what i bought to fix that problem
stainless bolts
status report
well i failed miserably - went and bought an impact drive...hammered away with zero results for about 30min. Thought well fark this bit that came on this impact drive will fit my impact gun! :D Nailed the first screw and ziiiiip - thing flew right off, after taking a look at the bolt itself it looks as though the PO coated it with some sort of loc-tite or similiar product. Well that was easy moved onto the other three...first one took about three discharges from the gun before stripping like butter :doh: the other two were similiar except on one try it completley twisted the bit :doh:
so how f*cked am I? The tops of the bolts are pretty much useless as there is now a cone shaped hole bored in each of them :whoops: Any chance a shop or machining shop could make short work of these damn bolts???
kj
Drill out/off the heads and go from there. Once you have the hinge off, soak them again. You maybe able to get a pair of vicegripa on the stubs. otherwise you will have to drill out the screw too. Not impossible just time ....
Nocents
Try to file/cut a slot for a flat screwdriver bit and go back to the impact driver, not impact WRENCH!!! After a few hard hits with a BIG hammer (BFH) but some channel locks on the driver and push in with one hand while trying to turn with the channel locks. The impact driver will work! So the one that finally came out with the impact wrench... must have been the one you were working on with the driver!
Sometimes drilling a SMALL hole down the center of the bolt shaft will heat up the thing enough to break the rust seal, and you'll end up spinning it out the other end.
I was at my stash last weekend ad needed a WS hinge, I had my regular trail tool box, no impact driver, so I removed 8 by using a sharp chisel and a hammer, just drive the screw the proper direction, it ruins the screws, but, better than the alternative.
Butch
Thanks for the comments and tips guys\gals Im gonna take another wack at these bastids tomorrow using a few of the suggestions posted here.
TIA
will report back - kj
I get my #3 Phillips from Craftsman so when I bust them (not if) I can get more. I usually get 2 or 3 at a time to save trips to the store. I also found that most impact drivers have removable 3/8" heads and sometimes I just pop the head and put it onto a 3/8" breaker bar so I can get better leverage. I also learned that the first shot is your best shot, so try the impact or breaker bar with a fresh screwdriver bit on a screw that no one has tried to turn yet.
Drill the others and retap. Chiseling worries me.
try using Kroil it works better than anyother stuff.
next I try to get it off using the proper bit(philips) on a socket wrench, push down on the top and turn, works alot better than a screw driver. When/if that strips out the head...........
I cut as deep a slot in the head for a flat bit, use the rachet again.
Only had a few that did work on.
