32/36 carb probs
Discussion in '40- & 55-Series Tech' started by bonzai, Jul 27, 2005.
  1. bonzai
    bonzai
    341
    Jun 28, 2005
    Colorado springs
    Take it easy on me I just got the pig yesturday
    How do I make my carb weber 32/36 go from open with the throttle closed
    to closed with the throttle closed.
    As it is it stays open all of the time
    FJ55 f engine 4 speed
  2. madoc1
    madoc1
    436
    8
    May 28, 2005
    spicewood,tx.
    wd-40? you have a linkage problem. climb inside with motor off and wigglle a lot.
    lots of luck.
  3. Yotahilux
    Yotahilux
    196
    Apr 29, 2005
    VA
    I believe that I have the same carb on my pig. Would pics of my carb help? :confused:
    Ethan wrote:
    the longer I have my weber the more problems I have with it. Im planning on going to stock. hey want mine? it works. hehe.....no really.
    I agree with Ethan :doh:, I have a stock 76ish carb just waiting on funds to get it rebuilt. :grinpimp:
  4. Ethan
    Ethan
    95
    May 15, 2003
    Northern California
    really though when I get my stock carb going that weber is going to who ever needs it.
  5. bonzai
    bonzai
    341
    Jun 28, 2005
    Colorado springs
    I take it the stock 1 and 2 barrel carbs are better?
  6. CruisinTiger
    CruisinTiger
    2,973
    146
    Oct 22, 2004
    Clemson, SC
    Are you sure your throttle cable isn't stuck open...what I mean is, is it returning back to the closed position itself? I had a bad throttle cable and when I pressed on the gas peddle it would stay open due to rust and junk in the cable...just an idea.
  7. Ethan
    Ethan
    95
    May 15, 2003
    Northern California
    I heared from a good source that the weber carbs will make your motor run good for a while. The problem is that your stuffing your cylinders with to much fuel washing the walls clean and causing wear. Sure someone will come one here say that they have run theirs for a long time and its been good. BUT Its not worth the risk. plus I have had so many other problems with them that Im ready to go to stock. I have never heard any bad thing about stock other than they don't give as much power. I have a Land Cruiser not a hot rod you need to understand that if you have the 6 cyl. your not going to go fast. swap out if thats what you want. just my 2 cents
  8. bonzai
    bonzai
    341
    Jun 28, 2005
    Colorado springs
    nope not the throttle cable
    Damn carbs
    My buddy said to take off the plate on the engine side and adjust the tension screw for the flappy things.
    Giving that a try manyana.
    Thank you for all of your input
  9. 65swb45
    65swb45 Elder Statesman Supporting Vendor
    24,383
    9,420
    Apr 14, 2004
    818-953-9230
    Try a heavier return spring.
    Also disconnect the accelerator cable and make absolutely sure that there is not a burr in the cable that could be sticking. They don't last forever.
  10. bonzai
    bonzai
    341
    Jun 28, 2005
    Colorado springs
    Removed the spring housing on the engine side of the carb and wouldnt you know it. The post that controls the flapper things(i would like to know their name) was not connected.
    So reconected the post found the sweet spot. She runs sooooo much better now.
    Plus my confidence meter went up too.
    Seeing as how I was messing with the engine I took this opertunity to change the oil and filter. Doing this gave me an excuse to change the oil in the wifes Jeep as well. Fun Fun Fun.
    Quick Q where is the best place for an oil filler cap function over form Prices?
