Gr8Pmkn
I have a 3000 mile 2F Engine from a FJ40 (not sure of the year 75+, engine # 346712), transmission & transfer case sitting in the garage that I am in the process of tearing into. A little history on the engine, I purchased it a couple of years ago from a Chicago area CruiserHead on the LCML. The history I was given was that it had come from a FJ40 that lived its years as a plow truck at a Toyota dealership, and when the body rotted away, they sold the rest for parts. I forget if I was told the mileage read 3000 or if it was 1500 and we were figuring x 2 for forward and backwards plowing any way, it sure beats mine with a blown head gasket or worse. I was told the engine ran when it was pulled, but have not seen it run. On my part, I have also made a point of turning the engine over every 2 – 3 months which it has always done rather easily by hand with spark plugs removed..
Here are some pictures of the engine as I took it apart that I hope confirm the engine’s history - I did not clean anything with the exception of the head which I sprayed the valves with a little carb cleaner. The valve cover from this engine is the gleaming silver one and the filthy black one is from my old engine. More are available here http://lscomputing.net/Engine/Engine.html
My plan is to preemptively replace gaskets and seals to be safe while everything is out of the truck. I’m sure I’m missing some, but this is what I have on my list:
From a SOR kit (032-01E Vlv Regnd Set-8/80-8/87*Japan) that was “given” to me when I bought the engine: Head Gasket, Manifold Gasket, Valve Cover Gasket, Valve Cover Seals, and Valve Stem Seals
I was also planning on replacing the following: Rear Main Seal, Side Cover Gasket, and the Oil Pan Gasket. I am not sure if I should also do the Timing Cover Gaskets and seals before I put it in as well.
I was not planning on doing anything to the lower end, unless there is something that I am missing.
For the head I am wondering if I should or need to do anything. If it is not warped with a straight edge is there any reason I need to have the head machined? If I were to get it machined how much should I have shaved or how much can I shave and still run normal octane fuel? I am planning on upgrading to headers and will be switching to an electronic ignition from an FJ60.
For the transmission & transfer case, I am planning on replacing gaskets and seals as well.
I am just trying to make sure I get everything ordered at one time, since no one seems to have any thing locally in the Chicago area.
Please let me know if there is anything I am missing or something that I could do to make this project better.
Thanks in advance.
Lee
Thanks in advance.
Lee
