OK, so I'm working on this 66' here: 1966 FJ40 Frame-Off Build (3rd Generation Owner)
I'm now taking a total of 3 used three speed transmissions to make one decent one for this restoration. Bearing question though, I was installing the input bearing on the input shaft and I noticed that the rear of the bearing is not "open", it's closed up with a metal shield. I've done lots of transmissions before and I've never seen this. The OEM bearings are obviously open to allow oil to flow and lubricate the whole works. The bearing numbers are "almost" the same. Both the input and output bearings are the same size.
Should I chisel off this metal guard? I'm concerned that the bearing is going to receive zero oiling with it in there. Need some advice, here are the pics
