Hey all,
I’m in the process of rebuilding a H41 transmission mated to a 3-speed transfer case. I’ve rebuilt a 4 speed case before, where there are still hone-able gear bushing available, but my understanding is the thicker 3-speed bushings are no longer available.
This could be a problem as this is my EDIT: high range (smaller) gear:
I’m guessing this is probably too far gone to run. There’s a bit of play between the gear and the shaft as well.
The larger EDIT: low speed gear seems ok, although theres a substantial wear pattern on the rivets:
Similar story on the input shaft:
Input shafts are still available, though this one could potentially clean up - but if the thicker bronze gear bushing supply has dried up, are there any options to salvaging this case beyond finding another gear with a good bushing? If not, does it make more sense to swap the gears, and risk gear whine, or to press out and swap the bushings?
