3 spd t-case can't shift
Discussion in '40- & 55-Series Tech' started by laguna80, Feb 19, 2009.
  1. laguna80
    laguna80
    1,158
    5
    Sep 27, 2006
    HI
    I've got a problem that's been bothering me for a while. 74 FJ55 stock 3 spd with warn hubs. I can shift from 2 hi to 4 hi but cannot shift into neutral or 4 lo no matter what amount of force I use. All the linkage seems to be in working order. Any ideas? Need more info? For the life of me I can't find anything in search.
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,429
    Media:
    17
    Albums:
    1
    875
    Oct 1, 2003
    MN
    Get under the truck, have someone else manipulate the transfer case shifter and see what is going on when things move around.
  3. inkpot
    inkpot SILVER Star
    13,194
    2,624
    Jan 30, 2003
    All over Arizona
    Howdy! Shifting from 2 hi to 4 hi only moves the linkage that is hooked up to the front output housing. Basically, it is just a long extended arm that is a solid part of the shift lever. For Low range, moving the shifter sideways SHOULD move the linkage lever that connects to the pivot arm that sticks up out of the top of the main case. If the shifter up in the cab moves sideways OK, but nothing happens, then the linkage is loose. If the shifter won't move sideways, then the linkage is mounted wrong, the links are frozen, or there is a problem inside the case. John
  4. 35inchoverdrive
    35inchoverdrive Forge Specialties
    1,287
    684
    Jan 26, 2006
    VA
    Disconnect the linkage from the case, and see if you can push the tab on the outside of the case to cycle between Hi & Lo. This should help you decide if it's the shift linkage or the internals of the case.
  5. 65swb45
    65swb45 Elder Statesman Supporting Vendor
    24,368
    9,382
    Apr 14, 2004
    818-953-9230
    1. It is MUCH MORE common to have a problem between 2-4 than from H-L, which makes your situation unusual.
    2. A 3 speed in a 74 is also uncommon. Most [but not all] 74s came with a 4 speed.
    Which leads me to wondering if your vehicle may have been tampered with.
    Remove the boot that covers your transfer case lever.
    See if the lever is hitting the floorboards.
    Look to see if the stamped steel shift gate is in place
    Look to see if the shift gate has an L shape to accomodate both the 2-4 and H-L functions.
    Report back on what position your lever sits in in the 'L' if you have an "L' shaped gate.
    Best
    Mark A.
  6. lcwizard
    lcwizard Supporting Vendor
    4,326
    Media:
    13
    Albums:
    2
    2,637
    Dec 5, 2004
    Miami, Arizona
    Do the easy first . There is a plug on the top of the case that retains a spring and ball bearing. The ball's
    purpose is to lock the shift rail into position. If the ball wears down too small ( not common, I've only seen it once ) it can fall deep enough into the shift rail detents that it won't roll out as the rail moves forward or back. The rail stays locked in one position.
    Back the plug out and see if the shift rail moves
  7. 65swb45
    24,368
    9,382
    Apr 14, 2004
    818-953-9230
    A split case thought for a single-piece t-case. Won't work Dave.:frown:
  8. lcwizard
    4,326
    Media:
    13
    Albums:
    2
    2,637
    Dec 5, 2004
    Miami, Arizona
    That's right, that only applies to split cases. It show how long it's been since I've run a one piece.
    About 1984. After I took apart my first split case, i couldn't justify the one piece.
  9. laguna80
    laguna80
    1,158
    5
    Sep 27, 2006
    HI
    The rig is definitely all stock. It's production date is one of the transition months. 9/73 It's got the 1.5f engine and the 3 spd changed in the next couple of months during production. Am I right on that?
    I do have the L-shaped gate and the shifter def. has enough clearance to get into N and 4L. I'll get under there more and have someone work the linkage to see what else is going on.
  10. Living in the Past
    Living in the Past SILVER Star
    16,259
    2,988
    Apr 21, 2005
    Here's a diagram I borrowed from SOR's site. It shows the shift linkage of the 4/75 and earlier transfer case which is different than most transfer linkage of cruisers out there. The arm that shifts between hi and lo is out to the side of the transfer case instead of towards the front. The rod that shifts it runs to the front and then pivits at the 2H to 4H shifter over to the floor shifter. I would unhook the rod right at the transfer case then check to see if the shifter will move. This is easier to do than shifter the transfer case by hand from below. That is unless the FJ55 inspection cover allows you to remove it easilly to do it from above, never owned a FJ55. The FJ40 tranny doesn't come out that easy. It could be the arm is rusted to the shaft that screws in to the 2H to 4H shifter if not that then probably in the transfer case.
  11. wombat
    wombat
    1,207
    184
    Nov 13, 2006
    Victoria B.C.
    same thing happend to me, i found shaft#10 was siezed to pivot #5. lots of penetrating oil and gentle tapping freed it up,cleaned it up,lubed now works great
