3 on the tree linkage adjustment.......
Texican
s-Moderator
Bonham Tx.
I dropped a fresh 2f in my 71, had to tweek the shifter arms to clear the header and shorten one, now it is stuck in low-reverse......I have an FSM for my 65 FJ45 and it shows a hole to line up the shifter arms to index neutral, then adjust the rods to match, ...........
What is the procedure for the 71:confused: I do not see any hole for a alignment pin......
Butch
65swb45
Elder Statesman
Supporting Vendor
Website
www.marksoffroad.net
Even if I knew of this alignment hole [and I don't] I wouldn't tell you.:flipoff2:
Seriously, I wouldn't bother with any factory indexing for the simple reason that you have entered the world of 'custom.' Rule #1 in the world of custom is......
form follows function.
Assuming that the top cover of the trans is properly installed, just swing the top arm back and forth to study the range of motion needed to move the gate from side to side, and adjust the linkage to match.
I have noted that it is WAY TOO EASY to overtighten the bolt at the bottom of the column that holds the linkage for that swing arm, so you might want to try loosening that up first...just for SAG.
Best
Mark A.
P.S. never got your RSVP.
Texican
s-Moderator
Bonham Tx.
What exactly do the two arms control on this trans?
I'm used to the old Saginaw where one arm is 1st--R and the other is 2-3........
Sorry I did not RSVP but did you really expect me to show up in Kalifornia?
