2UZFE oil starvation on hill climb (1 Viewer)
Chatsworth, CA
From a road course racers point of view. I see many race engines use an oil reserve tank (accusump) to keep the bearings oiled during high lateral G cornering since oil in the pan is sloshing to one side.
Since climbing a steep hill will slosh the oil to one side of the pan, is there a posibility that the Toyota 2UZ-FE engine will have an oil starvation at an extreme vehicle angle?
I had a few non extreme off roading trips and never saw the oil pressure light come on. Here are some pictures of my "sold" GX470 at truck hill trail at Hollister Hills. Thank you very much!!
e9999
You want to do what...?
Moderator
US
that middle photo is interesting...
Did you manage to roll it over? that was a good try!
Chatsworth, CA
It still had some good weight on the driver side so it is not close of rolling over. I decided to drive down the same path I came up and it was a totally different experience. I wasn't able to use DAC because it requires the truck to speed up a little then it will slow it down which I will not take a chance on this decent.
The trail was very slippery and the rear wheels kept locking up and making the truck sideways. Very very scary. I also was running on fully inflated tires (which didn't help) and ride height set to high which I should set it to low or normal to put some weight back in the rear tires.
powderpig
Boulder Foothills, CO
I have not had a UZJ engine apart yet, but the pervious engines for cruisers here in the states have had oil traps (lack of better word) around the oil pick up to help control oil from starving the oil pick up. So my guess is that there would be this trap or baffle in the UZJ engine as well. But this would not work so well if the truck was on it side or upside down for very long. later robbie
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
