FunkyYota69
I swapped a 2uz-fe w/ A750F from a 2003 UZJ100 into my FJ80.
Everything is working great, except the throttle. I read through the APPS/TPS FAQ sticky, but I haven't found a problem that sounds quite like mine.
When I mash the pedal the throttle will open, but after a certain point it suddenly drops to idle. This is 100% repeatable.
I replaced the APPS w/ a junkyard unit a couple times - the problem is repeatable w/ each of them.
The scan tool says the TPS reading is 82.4% max. Beyond that it drops down to about 16% or so, depending on engine warm up cycle/temp.
Next steps are TPS or the throttle valve actuator, but has anyone seen this before in their J100? If so, any suggestions? Thanks in advance.
