In my quest to get my 2UZ running stand alone (with aftermarket ECU and harness) I have hooked up a 255lph fuel pump and aftermarket OEM style filter. The pump is pumping. I know this because when I disconnected the output of the filter I got a spray of gasoline (!).
I am wondering what the expected behavior of the pump and fuel system should be... In my case when I turn the ignition power to ON the pump turns on for a few seconds then turns off. When I crank the engine it cranks but does not try to start and no fuel comes out of the return fuel line.
What is supposed to happen?
